Well, after a long absence on this build it looks to be getting back on track.
I located a 77 550 bottom end from Gennaro (fellow Sohc4 member) and that is going to be sent to Mark (Hondaman) later next month. I have had my NOS primary, cam chain, and all lower end seals boxed up for almost 5 months awaiting shipment to Mark. He will do his thing on the lower end. I just don't want there to be any questions and I know if I do it, there will be plenty of best guesses. haha.
Since the electronics pan is too small to house both the battery and M-unit, i'm tinkering with the idea of making an alloy bracket for under the rear cowl that I will bolt to the factory plastic mud guard. I mean the battery is light enough that it shouldn't be a problem and then I won't have to weld or repaint anything on the frame. It seems like the best solution. Option two is to make a small battery sling that I can fasten to the swing arm.
Anyway, I'm not really doing much until the bottom end is done. I have seriously been dreaming about assembling the top end and firing this thing for the first time. I cannot wait to hear how it sounds.
