I finished designing and fabricating the rear bolt-on "Multi-Brace". I made it by hand out of 6 pieces of 1/4" stainless steel. Just cut, clamped, mig welded, ground, and drilled/threaded. This piece supports the rear end and replaces the higher, factory brace which I cut out of the frame. It also mounts the tail light below and the M-unit above (under the rear seat cowl). Lastly, the brace will hold the small Motogadget turn signals just below the fame tube. So many functions for one piece.
I'm going to look around at prices for powder coating around here to have the Multi-Brace, seat mounting pieces, and motor mounts done.
These shocks are going on the 78 and I picked up a pair of Ikon shocks that will be going on this bike. The tail light to the tire is 3.25" with the 13" Progressives. The Ikon's are 12.5" long and total compressed length brings them down to 10.2". This means I'll still have over 2.4" of travel before the tire would hit the taillight.
The crank case is currently with Mark but he's in the midst of a few other projects so I'm just waiting my turn. Once that is back from him it's time to assemble the top end and go.
While the lower end is in Mark's care, I'm going to start on the wiring harness.
Multi Brace 1 by
Jared Chilko, on Flickr
Multi Brace 2 by
Multi Brace 4 by
Multi Brace 3 by
Multi Brace 5 by
Multi Brace 6 by
