Author Topic: Early CB750 KO - Start Again  (Read 40620 times)
Offline dhall57
Re: Early CB750 KO - Start Again
« Reply #125 on: January 11, 2014, 03:17:36 PM »
I knew this kitchen would come in handy someday! When the wife is away the kid must "spray".  ;)
Make sure all the evidence is out of the kitchen before the boss(I mean wife) gets home Johnie or the kid might be sleeping in the garage with the CB's ;D
« Last Edit: January 11, 2014, 03:21:44 PM by dhall57 »
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Johnie
« Reply #126 on: January 11, 2014, 07:48:16 PM »
Hall...in the shop with the CB's...it could be worth than that  :D
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Johnie
« Reply #127 on: January 12, 2014, 09:04:59 AM »
Took the tank badges and put them in some old Gumout carb cleaner. The paint just fell off in sheets. That was easy. Time to paint these in the OEM flat black. Will use a small model brush and some model paint. Worked well on the other badge sets I have done. I will put up more pics when done.
Oshkosh, WI  USA
Offline dhall57
« Reply #128 on: January 12, 2014, 09:28:51 AM »
I did mine just a little different Johnie because my hand is not that steady to use a brush in that small area and figured it would take less time and just work better for me. Not OEM but used a can of flat black spray paint and covered the entire nameplates with paint. When the completely dried took my pocket knife and gently scraped the paint off the area on the nameplates(by looking a pics) that needed to be bright.
« Last Edit: January 12, 2014, 10:00:15 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Johnie
« Reply #129 on: January 14, 2014, 02:15:01 PM »
Moving right along...got the master and caliper rebuilt today. The caliper piston was in suprisingly great condition. Not ready to install the brakes yet, but I think I am procrastinating on polishing the fork legs :) Polishing is not one of my favorite tasks...but the show must go on. Need one more coat of paint on the black items and then I suppose I have to start the polishing...
Oshkosh, WI  USA
Offline MikeKato
  • Milwaukee WI
    • TCB true life stories
« Reply #130 on: January 17, 2014, 06:14:43 PM »
  I saw what a nice job you did on your other badges and stator cover (fine tip marker) so I went and got the paint and brushes and tried it myself last summer.  Found out it takes a lot of patience to get them looking as good as yours does. That task gets a guy as nervous as a narcoleptic bomb diffuser with tourette's syndrome, so now I get to see if I can at least strip my badges as good as you.   Nice work on your bike!
Offline Johnie
« Reply #131 on: January 18, 2014, 06:01:12 AM »
Thanks Mike...my other KO tank badges turned out real nice with the flat black. For some reason this time using enamel they did not turn out to my liking. So I stripped them again and instead taped off the chrome and sprayed them. Still need to remove the tape and clean them up. Will post a pic when I get them ready.
Oshkosh, WI  USA
Offline Damfino
« Reply #132 on: January 18, 2014, 11:31:26 AM »
I'm a huge fan of your work Johnie, so consider me subscribed!  ;)
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Johnie
« Reply #133 on: January 18, 2014, 12:30:39 PM »
Welcome damfino...where you been hiding?
Oshkosh, WI  USA
Offline Damfino
« Reply #134 on: January 18, 2014, 01:25:30 PM »
Hiding? I'm always lurking somewhere... ;D
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
Offline Johnie
« Reply #135 on: January 24, 2014, 03:35:40 PM »
As noted above, I was not happy with the hand painting of the badges so striped them again and started over...only this time I used the flat black spray. The picture shows the bottom badge done. The top one in the pic I still need to remove the paint along the HONDA edging. I am much more pleased with the spray and will do that next time too.
« Last Edit: January 24, 2014, 07:29:18 PM by Johnie »
Oshkosh, WI  USA
Offline Johnie
« Reply #136 on: January 24, 2014, 03:41:14 PM »
Packed the tapered steering bearings and got the newly painted triple back on today. Started to get the rear blinkers in order.
Oshkosh, WI  USA
Offline dhall57
« Reply #137 on: January 25, 2014, 12:20:12 PM »
+1 on them badges Johnie ;)
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline David B
« Reply #138 on: January 25, 2014, 01:54:30 PM »
Badges look great Johnie!
Don't know if you were planning to add the white as well, and you may already be familiar with it, but one method you might try is to use a fine brush (like a model brush) to paint on a mask over the black you wish to keep.  Then spray on the white, remove the mask & you are done  Worked well when I did redid my badges.  Be liberal in application of the mask. 2 coats can't hurt, it comes off easier that way.
Just a tip for those who haven't come across this stuff.  Most model shops should have it.  Hope it helps.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXC099&P=ML#
DB
Offline Johnie
« Reply #139 on: January 25, 2014, 02:36:43 PM »
Thanks Dave...I never knew the liquid mask existed. I will get a bottle.
Oshkosh, WI  USA
Offline jerry h
« Reply #140 on: January 25, 2014, 09:46:18 PM »
Love the free hand welds on your rear wheel picture above!  You can imagine the factory buzz at that time, trying to crank out as many as possible, as fast as possible.  Quick weld and move on. ;D
What's next?
Offline dhall57
« Reply #141 on: January 26, 2014, 06:20:38 AM »
Yeah Jerry after seeing the pic of the welds on Johnie's low #KO got curious and went out and looked at the welds in the same area on my 4/70 KO and they look about the same.
« Last Edit: January 26, 2014, 06:40:12 AM by dhall57 »
1970 CB750KO
1974 CB750K4
1976 CB750K6
1977 GL1000
Offline Johnie
« Reply #142 on: January 26, 2014, 06:51:53 AM »
Those welds do show a time when Honda just could not produce the 750's fast enough. More people were crying for them and they had to churn and burn at the factory to get them out ASAP.
Oshkosh, WI  USA
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #143 on: January 26, 2014, 07:02:19 AM »
Those badges look great John!  ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline David B
« Reply #144 on: January 26, 2014, 07:18:45 AM »
If you can't find it locally or want to just order it, Tower Hobbies is a great go-to. They'll have the tiny model brushes as well.
DB
Offline Johnie
« Reply #145 on: January 31, 2014, 12:38:59 PM »
UPDATE: Here are some before and after pics of the fork legs. Pleased with how they turned out. Will install the new seals and then have to wait for the fork ears from the painter. New front tire is on the rim and the wheel is ready to install. Ordered some new gauge covers & faces from LeCram. The current ones have cracks. Not sure if I will change out the faces as the OEMs are really nice. No warping and the only issue is fading on the tach orange zone.
Oshkosh, WI  USA
Offline bjatwood
  • 1973 CB750-K3
« Reply #146 on: February 02, 2014, 12:14:33 PM »
Your getting very good at polishing John! Those look better than new!! 8)
Brian
#24193
Offline Tews19
  • I am no
« Reply #147 on: February 02, 2014, 02:40:19 PM »
Great work Johnie! Have you ever posted your process of taking apart the rear shocks? I have a set of Koni's I want to clean up for my K1
1970 Honda CB750 survivor.
Offline edwardmorris
  • Youngish
« Reply #148 on: February 02, 2014, 03:56:35 PM »
Welcome back Nick. I posted in the FAQ what I did, pretty simple for the stock ones, maybe it will help you
http://forums.sohc4.net/index.php?topic=112903.0
Offline Johnie
« Reply #149 on: February 02, 2014, 05:20:33 PM »
Yah, welcome back Nick...good to have you on board again. Hope all is well my friend.
Oshkosh, WI  USA
