Author Topic: Early CB750 KO - Start Again  (Read 39122 times)
Offline edwardmorris
  • Youngish
Re: Early CB750 KO - Start Again
« Reply #175 on: April 17, 2014, 01:40:04 PM »
Thanks Johnie, I wasn't sure about replating, but replacement parts were just awful looking so I caved and started looking for a local guy too. Few miles west of Chicago, there's a guy named Mike at Calco Plating, who made me an offer I couldn't refuse despite the cost. Basically $1200 for everything chrome on the bike (except the pipes and rims), down to washers. Mind you, this deal is basically you get what you pay. I will post some pix when I do the unpacking and compare. I tore open the fenders and treated the underside with an Eastwood coating, and at least on the outer surface, they look good as new. He taped up the underside so they didn't get plated, but the tank ate away a lot of rust, so I used the undercoating to fully stop it where it is.
Edit: everything but the pipes and rims.
« Last Edit: April 17, 2014, 04:15:49 PM by edwardmorris »
Online Johnie
« Reply #176 on: April 17, 2014, 02:25:29 PM »
Sounds like a good plan there Ed. In looking at Terry's site I see he is offering free shipping.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #177 on: April 17, 2014, 02:31:50 PM »
I paid $150 for the front and $125 for the back.
Thats a good deal. I was quoted $200 for a front fender from my local plater, he is the only one in Austin.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #178 on: April 17, 2014, 05:24:18 PM »
Chrome looks Great Johnie! I am starting a new HK0 Trail 70 build and will definitely be giving Terry a call on some parts. Your not EVER gonna sell me that K0 now are you?!?!?! LOL
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline dhall57
« Reply #179 on: April 17, 2014, 06:06:47 PM »
Johnie you really go all out on your projects and do superior job. And this KO is no exception ;)
By the way Brian did you ever find you a good #2 341?
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
  • Youngish
« Reply #180 on: April 17, 2014, 06:10:58 PM »
Here's a sample Johnie, hope its good enough for the money. Fenders and fork tubes. I'm still waiting on some parts to return, so some day I'll post a pic of everything.
Online Johnie
« Reply #181 on: April 17, 2014, 06:44:30 PM »
Ed those pieces look very good to me. You even did the fork tubes...wow.
Thanks hall...I am trying to hold back on this one a bit in case I do sell it to keep the investment down, but that does not seem to be working :)
Brian - I have to tell you the same thing as the other guys - I can not decide what I am going to do with this one until I hear it purrrrrrrrrrrrrrrrrrrrrrrrrrr... :)
Oshkosh, WI  USA
  • Youngish
« Reply #182 on: April 17, 2014, 06:48:02 PM »
Thanks Johnie, I'll take some better pix when we actually get some sunlight. It was a whole bike deal, so everything that was chrome got rechromed (no pipes or rims ofcrs). I'm glad the fork tubes and their pistons and even the brake caliper piston now look brand new, just hoping this will work out and I can ride this thing forever. Or sell it to buy my first true love, the HD FatBoy ;)
Offline Old Scrambler
« Reply #183 on: April 19, 2014, 10:02:57 AM »
Ed...........and others..........some chrome shops tend to allow the parts they work on to 'grow' before they are returned to you. A few thousanths of copper-nickle-chrome will make a huge problem for fitment.  Please check your parts before you try to install.  I had that same experience with Terry a few years ago...........re-chromed handlebars were 'thicker' and the throttle-tube / perches would not fit.  I then sent a spare throttle tube to Terry and he 'fixed' the problem.  FWIW.........fork tubes and brake pistons have 'hard-chrome' finish which is quite different from show-chrome.
BTW.......good chrome will flex by 8 or 9% without cracking.  I have tweaked a few items after Terry did a chrome-job and found his work to hold up to the test.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Online Johnie
« Reply #184 on: April 19, 2014, 11:11:15 AM »
Good point Dennis...even the chrome fork ring I bring a fork ear so he knows not to get the chrome to thick. Terry does stand behind his stuff.
Oshkosh, WI  USA
  • Youngish
« Reply #185 on: April 19, 2014, 12:20:07 PM »
I've already run into that, the rear wheel axel only had chrome on the head and the threads, but to my guy, that didn't seem "right" so he plated the whole thing. I told him I was concerned it won't slide through freely and sure enough, simple test with a wheel bearing and it was too thick. I took it back with the bearing, and he removed it, thinned out the bolt few microns and plated it again anyway  :o but the bearing now slide through perfectly. Not sure why he couldn't let go, but my axel looks awesome now  ;D
Offline bjatwood
  • 1973 CB750-K3
« Reply #186 on: April 19, 2014, 03:28:51 PM »
The quest continues dhall! I look daily for one....
Brian
#24193
Online Johnie
« Reply #187 on: May 23, 2014, 11:34:01 AM »
OK OK...so it has been a bit since I have been able to move forward with this KO. Couple of factors...the PO had a fairing on it and really scratched up the frame in front of the motor. I was going to leave it, but the more I looked at it the more I knew I needed to paint it. So had to wait for warmer weather to paint. Then as luck would have it I landed a 1972 CB350K4 with 6,500 miles so I been working on that. The 350 runs good and I have been having some fun with it. So today I got the KO motor masked and pushed it into the paint shop. Once she cures I will be ready to move forward. Of course, now we are in the riding season so I make no promises as to the progress :)
« Last Edit: May 23, 2014, 11:37:22 AM by Johnie »
Oshkosh, WI  USA
« Reply #188 on: May 23, 2014, 01:56:12 PM »
Paint shop?
Online Johnie
« Reply #189 on: May 23, 2014, 03:58:47 PM »
Yah, that's the place where I paint. My car garage  :D
« Last Edit: May 23, 2014, 04:00:33 PM by Johnie »
Oshkosh, WI  USA
Offline bjatwood
  • 1973 CB750-K3
« Reply #190 on: May 28, 2014, 07:58:40 AM »
Isn't that the way it goes Johnie! I'm right in the middle of a Wing/Bobber project when that Chopper deal presents itself! Man did we need to build a Pole barn for a garage or what!
I have so much "stuff" in my MC garage i can hardley get any work done! LOL
Brian
#24193
Online Johnie
« Reply #191 on: May 28, 2014, 01:59:07 PM »
I here you...a guy always needs more space. Maybe it is time for my wifes car to sit outside :)
Oshkosh, WI  USA
« Reply #192 on: May 28, 2014, 06:23:06 PM »
Bet she won't like the sound of that.  I know mine wouldn't.
Offline Tews19
  • I am no
« Reply #193 on: May 28, 2014, 06:38:58 PM »
Thata boy!
1970 Honda CB750 survivor.
  • Youngish
« Reply #194 on: May 28, 2014, 08:42:44 PM »
Its only fair, women always take up more closet space, men should get the whole garage ;)
Online Johnie
« Reply #195 on: May 28, 2014, 09:23:33 PM »
Ed that is the most honest and true statement I have seen in a long time. It happens here too. :)  She can have all the closets she needs...I am not into closets, just shops and garage space.
Oshkosh, WI  USA
Online Johnie
« Reply #196 on: June 09, 2014, 06:00:26 AM »
June 9th - time for an update - the 72 CB350 is done except for the OEM mufflers which will go on soon. Now I can get back at this KO. I had painted the frame in front of the motor a couple weeks ago. This past weekend I got the side covers polished and the KO back on the lift for the final assembly. Put on the newly painted center and side stands. Glad to get back at it...
« Last Edit: June 09, 2014, 06:05:26 AM by Johnie »
Oshkosh, WI  USA
« Reply #197 on: June 09, 2014, 07:00:40 AM »
Nice job... nothing like freshly polished aluminum
Online Johnie
« Reply #198 on: June 22, 2014, 05:01:45 PM »
June 22nd...progress this weekend. Got the x-ring chain on and finally got the unstamped HM300's installed. Pipes 1 - 3 went on easy. Was having a difficult time getting pipe #4 to slide onto the spigot all the way. Messed with that for a while before I replaced the spigot with another. Turns out the spigot that came with the bike must have been rechromed and the chrome was to thick to allow this pipe to seat. Still waiting for my tins to get done. I am going to check with the painter this week. He has only had them since November...never took him this long before. Next comes installing the carbs.
« Last Edit: June 22, 2014, 05:32:26 PM by Johnie »
Oshkosh, WI  USA
« Reply #199 on: June 22, 2014, 07:07:41 PM »
Pipes look great, Johnie.  What is it with painters?  I had same issue and other members have too.
