Author Topic: Early CB750 KO - Start Again  (Read 40529 times)
Offline Johnie
Re: Early CB750 KO - Start Again
« Reply #275 on: September 27, 2014, 10:55:01 AM »
Thanks guys. Stev-o...how in the world did you know Lake Winnebago? The bike is running fantastic since I took care of the intake issue. I had a strange time yesterday when I was getting it ready to ride. I had no low or high beam? That was strange. Pulled the light and noted the H4 bulb in there. Looked good, but I had an extra here for the Wing so put that in and all was good. Strange how both filaments would go at once.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #276 on: September 27, 2014, 11:27:32 AM »
I use to get around! (Before I was married). Been to Elkhart Lake, the race track, my brother has raced SCCA race cars there.
Offline Johnie
« Reply #277 on: September 27, 2014, 03:08:13 PM »
Gottcha...I have been to Elkhart Lake track and met up with old scrambler and hoodleyhoo there. Great riding area too. Dennis does not live to far from there.
Oshkosh, WI  USA
Offline jerry h
« Reply #278 on: September 27, 2014, 05:50:42 PM »
Absolutely beautiful !!!!!!!!!!!!!!!
(what great pics you took too!)
Offline Johnie
« Reply #279 on: October 06, 2014, 05:09:03 PM »
Glitch in the project:
DAM the carbs on this 69 CB750. Was running good, but could tell I had that intake leak and replaced the #3 intake with an extra I had here. Ran good, but was having intermittent FAST idle issue. So I figured since the intakes are 45 years old I should install new ones. Done, installed, now having a terrible time trying to get the low idle set. I have started over more than a couple times. Start to get close, then she revs way up so I make one small adjustment and they all drop to zero on the Morgan sync. What the hell??? It is not like I have never synced 4-4 carbs before. I think I better walk away for a bit. I may just have to take the air box off again and bench sync and see where it is at. What has me so confused is she ran great and all I was going to do was get the low idle up a bit as she was a bit below 1,000. Now I know why I told old scrambler "I really do not need another 4-4 carb bike."
« Last Edit: October 06, 2014, 05:57:49 PM by Johnie »
Oshkosh, WI  USA
Offline Tews19
  • I am no
« Reply #280 on: October 06, 2014, 05:20:54 PM »
Maybe slap on a newer set of carbs is the way to go for the moment. It sounds like this is eating at you and by putting on a new set of carbs hopefully it will be the remedy. Then you have all winter to play with the original carbs and not worry about it in spring time and then ride the snot out of her. Well at least get her in your rotation of sweet bikes to ride!
1970 Honda CB750 survivor.
Offline Prospect
« Reply #281 on: October 06, 2014, 05:37:10 PM »
Moving right along...got the master and caliper rebuilt today. The caliper piston was in suprisingly great condition. Not ready to install the brakes yet, but I think I am procrastinating on polishing the fork legs :) Polishing is not one of my favorite tasks...but the show must go on. Need one more coat of paint on the black items and then I suppose I have to start the polishing...
Just reading the thread again.  Did you use a honda rebuild kit or aftermarket?  Some of the aftermarket ones had quality issues.
I feel your pain with the fast idle and high rpm.  Good luck.  We all know how it feels.
Current Bikes
1969 CB750  Sandcast #256
1971 CB750K1
1972 CB750K1
1975 CB400F
1975 GL1000 Goldwing
1954 Harley Davidson Panhead
1957 Harley Davidson Panhead
Toronto Canada
Offline Johnie
« Reply #282 on: October 06, 2014, 05:38:22 PM »
Thanks Nick...I hear ya' ;D I do have an extra set of carbs here. This is a small issue compared to what you went through recently. It will get sorted...but you are right...it eats at you. Especially when I had the high sync spot on a month ago and she ran great except for the intermittent high idle. Now today even the high idle was off so I put the Morgan on it and got it spot on, but the test ride shows it runs like crap? I don't get it, but guess I will let it sit a bit and think it over...there is always tomorrow...unless I need the snowblower :)
Prospect - the bike ran great a month ago and up until today. Even the early test ride today was great...all I wanted to do was increase the idle a bit. Then it all went into the crapper. Regarding the carbs, I had them ultrasonic cleaned at my dealer and used the same jets that were in there. I did clean all the jets...I am going to take them out again to be sure they are clear. Should be...tank has a new liner and like I said ran great for the past month. Heck, it is not like I never synced 4-4 carbs before. Maybe some crap found its way into a jet which could account for the weird sync readings.
« Last Edit: October 06, 2014, 06:00:16 PM by Johnie »
Oshkosh, WI  USA
« Reply #283 on: October 06, 2014, 06:00:55 PM »
Step back, Johnie, we've all been there.  There is an issue and you need to find it and resolve.
Fixing it will be the easy part, finding it is not.
Offline Johnie
« Reply #284 on: October 06, 2014, 06:48:25 PM »
Stev-o...you are "right on". I got her back on the lift and in the next day or so I am going to check those jets first. It is just to weird. I should have never messed with the high idle since it was set a month ago. But with the new intakes I thought I should check it. Man, she sure ran good early today :) I keep telling myself this is fun and this is why we do it. :) What knocked me down was this was going to be my final sync with the new intakes and I could call it done...and then it just sucked the air out of my lungs.
Oshkosh, WI  USA
Offline dhall57
« Reply #285 on: October 07, 2014, 03:37:09 AM »
Johnie breathe in breathe out and relax. Jump on one of your other 750's(you do have one or two other's you know) ;D and get some wind in your face. This always help me ;)
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
Offline Johnie
« Reply #286 on: October 07, 2014, 06:30:52 PM »
Got the carbs off again tonight. Found a couple issues. One slide was stuck up in the holder a bit do to the cable. And a vent tube aluminum nipple had come off the side of #1 carb. Pulled plugs and they are black and sooty probably from trying to sync the carbs for a couple hours. There is only a few hundred miles on them, but probably should change them out. All jets were clean. Used some blue Lock-Tite on that loose vent tube. Making progress..."serenity now." :)
Oshkosh, WI  USA
« Reply #287 on: October 07, 2014, 06:39:48 PM »
Sometimes it's good to find issues...
« Reply #288 on: October 12, 2014, 10:32:20 AM »
Johnie late to the party but the bikes looking great - get some of those scenic shots over to the SOHC Calendar thread!
Good luck with the carb issues,
cheers
Andy
Offline Johnie
« Reply #289 on: October 12, 2014, 03:41:35 PM »
Got the bike out today and did the sync after taking care of the issues noted above. She pulls like a freight train down the expressway and runs good. Now just have to dial in the slow idle we should be set to go.
Oshkosh, WI  USA
Offline Johnie
« Reply #290 on: February 06, 2015, 12:50:12 PM »
Well, you know how you tell yourself this is as far as I am going with this bike. :) Did a little more chrome to dress it up. Also painted the swingarm after having Hondaman do the bushings for me. Now if this snow would just melt...
« Last Edit: February 06, 2015, 12:52:34 PM by Johnie »
Oshkosh, WI  USA
Offline Restoration Fan
  • My wife will never call me
« Reply #291 on: February 06, 2015, 06:24:48 PM »
Snow?  What snow?  It's supposed to be 63 here tomorrow :)
« Reply #292 on: February 07, 2015, 12:13:38 AM »
Mid 70s here
« Reply #293 on: February 07, 2015, 01:31:30 AM »
Mid 70s here
Here too.    If there was snow here, I'd have to buy a snow mobile.
Offline Johnie
« Reply #294 on: February 07, 2015, 04:59:55 AM »
Well and there you go rubbin' it in. Gosh fellas :)
Oshkosh, WI  USA
Offline Old Scrambler
« Reply #295 on: February 07, 2015, 12:29:11 PM »
Your not alone...........snow and cold at my garage ;)
Are you still looking for a decent dyno-cover?  Its been sitting on my bench for a few months........not perfect, but no deep scratches or rash.
The running CB750K0 that I acquired last year is likely to be parted-out. The frame and motor would make a good candidate for a 750CR project.  I'll begin wrenching on it when the snow melts. Let me know if you need any parts..........clocks, upper triple, fork legs, front brake & wheel, oil tank..........
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
« Reply #296 on: February 07, 2015, 12:32:09 PM »
Yes, if Johnie doesnt need it.  Thx
Offline tweakin
  • tear down
« Reply #297 on: February 07, 2015, 04:25:01 PM »
Ive been away for a bit and missed this one wrapping up.  Excellent work, turned out great Johnie!
Offline thirsty 1
« Reply #298 on: February 07, 2015, 07:12:10 PM »
I gotta say that you do some really nice work. I've been watching this come together for a while now and just wanted to say congrats!!!
Offline Johnie
« Reply #299 on: February 07, 2015, 08:42:13 PM »
Thanks guys for the comments. Much appreciated for sure from you other 750 collectors.
Oshkosh, WI  USA
