Author Topic: Looks like Hondabond on intake manifolds  (Read 1553 times)
Offline grepper
  • Busted Knuckles
« on: October 29, 2013, 06:16:12 PM »
Looks like some sort of sealer like hondabond.  How do I get this stuff off?
Offline harisuluv
Re: Looks like Hondabond on intake manifolds
« Reply #1 on: October 29, 2013, 06:32:31 PM »
Interesting, is it hard or soft?
Offline MoMo
  • Ride like you're invisible
« Reply #2 on: October 29, 2013, 06:42:04 PM »
Do you need to soften the manifolds?  If so, the xylene/wintergreen should loosen that stuff...Larry
Offline thirsty 1
« Reply #3 on: October 29, 2013, 07:06:44 PM »
That's what she said when the bed broke...
Offline bjbuchanan
« Reply #4 on: October 29, 2013, 07:38:23 PM »
I let it sit in xylene. The stuff is mean and eats up any of that stuff and at the same time it softens up the boots
I will probably catch flack for this but I take silicone and put the thinnest swipe on he inside of either end of the boots. Real thin and let it set up. Makes that perfect seal easier. I have new boots that still didn't want to seal so I gave it a shot after bs'ing with a friend and him mentioning I "forgot" to put sealer there. I gave it a shot considering a car would probably have sealer on something like that, seems to make sense. It works great btw
« Reply #5 on: October 29, 2013, 09:34:59 PM »
Try rubbing some brake cleaner on a rag on it but be careful with the rubber.
« Reply #6 on: October 30, 2013, 06:06:14 AM »
Lacquer thinner is handy stuff to have around the shop, plus it smells good  :)
Offline grepper
  • Busted Knuckles
« Reply #7 on: October 30, 2013, 06:44:10 AM »
It's hard, I tried scrubbing it off, but getting nowhere.   I'll try some Lacquer Thinner, then brake cleaner.
I'm actually doing the xylene/wintergreen thing right now.
I'm in the process of restoring a 75 cb750K.  I bought a parts bike, so luckily I have two sets.  The other set looks good, but hard as a rock.
Offline bjbuchanan
« Reply #8 on: October 30, 2013, 07:31:06 PM »
The xylene concoction works well on the thicker head rubbers but the airbox ones in my experience, and a couple others too, are just a waste of time. The soften up but warp and shrink weird and get rock hard really fast
I bet that sealer will just about fall off after soaking the boots
Offline grepper
  • Busted Knuckles
« Reply #9 on: November 06, 2013, 08:27:02 AM »
Thanks for the advice.  The airbox rubbers were already a little deformed and softness was uneven.  Plus I had them soaking already by the time I read your comment.
So, I have them drying on old light bulbs.
The one on the left is fresh out of the soak, the others have been drying for a few days.  Those have nice uniform softness and have a nice Velocity Stack shape.  I'm very pleased with the results.
Those other boots with the sealer on them are soaking now.
Offline grepper
  • Busted Knuckles
« Reply #10 on: November 07, 2013, 09:52:01 AM »
Sure did, the stuff came nearly fell off in the xylene/wintergreen  soak.
« Reply #11 on: November 07, 2013, 12:52:58 PM »
Buy a new set. 8 good clamps too.
