Author Topic: CB750F2 time to clean up the old girl. BACK TOGETHER! First ride!  (Read 7498 times)
Offline CB750R
  • 77 CB750F
Hello all,
I've been a member on here since 2005, I've had a lot of fun working on and riding this bike over the last 8 years.
I purchased a bit of a running basket case... and got the bike running and have made some big changes along the way.
I've installed FZR600 Wheels, brakes, and front forks,  the Wheels rotors and rubber weighed 50lbs less than the stock
setup!
I rebuilt the engine after having a valve break.  Using a spare bedroom I replaced the conrods, pistons swapped the head, and have had a trouble free engine (although I have a minor leak due to a not so repaired engine case from what I guess is a chain break incident.
Replaced mismatched side covers with reproductions, changed the tail light, signals, bars.
One thing I've never been able to do a decent job of is paint!  My bike has had at least 3 paint jobs by yours truly, but I just dont have the touch!
I just turned 35, and I'm recovering from a broken hip, as a treat to myself I'm taking this winter to freshen up the old girl, and get the bike painted "For REAL"  clean up some things that I've had on the to-do list for a while and hopefully both the bike and I will be ready for spring!
Here's one paint attempt, after I rebuilt the engine got the bike back on the road:
P5080031 by CB750r, on Flickr
Here's how it looked this summer:
Cb750r. by CB750r, on Flickr
and here's how it looks now!
« Last Edit: May 26, 2014, 08:18:44 AM by CB750R »
Re: CB750F2 time to clean up the old girl.
« Reply #1 on: October 31, 2013, 09:45:53 PM »
I like the Eddie Lawson replica in the background!
Offline CB750R
  • 77 CB750F
« Reply #2 on: November 01, 2013, 12:33:34 PM »
Thanks, its a 2000 ZRX1100,
For when the speed of the CB isn't quite enough I cheat with the Z!  at just shy of 130hp it makes passing cars much MUCH easier!
Here's a shot of the "NEW" tank I found at a bike salvage dealer in Northern BC!
inside looks like its brand new, there was 4 different paint jobs on this thing and I thought I'd find a bunch of bondo and dents, but to my suprise this tank was in pretty clean shape under all that old paint!
Here's a shot of the underside being prepped
CB750F by CB750r, on Flickr
« Last Edit: November 01, 2013, 12:42:03 PM by CB750R »
Offline CB750R
  • 77 CB750F
« Reply #3 on: November 01, 2013, 12:43:26 PM »
More prep shots of the body work:
Tank in Primer:
Offline Bankerdanny
  • Endeavor to persevere
« Reply #4 on: November 01, 2013, 01:17:27 PM »
I much prefer the muffler at the less extreme angle.
What color are you planning?
Offline CB750R
  • 77 CB750F
« Reply #5 on: November 01, 2013, 01:38:40 PM »
Thanks,  Ya I was trying to make it a little too much like a 90's style Super sport with that angle!  I'm looking into a stainless system from MotoGPwerks.
The colors are going to be similar to the stock, black, with red stripe, but outlined in silver instead of gold.
I think I get to pick up the parts today! I got this as a sneak preview today!
Offline lwahples
« Reply #6 on: November 01, 2013, 03:28:00 PM »
Nice sneak peak!
Offline barney fife
« Reply #7 on: November 01, 2013, 07:04:41 PM »
Can you share some info about the getting the wheels and front forks to work.  It is unbelievable how heavy the stock ones are.
Offline CB750R
  • 77 CB750F
« Reply #8 on: November 01, 2013, 07:19:36 PM »
This is the thread for the wheel and fork install.  I did this several years ago now.
http://forums.sohc4.net/index.php?topic=1563.msg16330#msg16330
« Reply #9 on: November 01, 2013, 07:36:19 PM »
I like the paint scheme!
Offline CB750R
  • 77 CB750F
« Reply #10 on: November 03, 2013, 05:30:03 PM »
So today I pulled out the battery tray out of the bike, grinded the crap outa rust thanks to the vent tube popping off the battery.
Also welded a bead onto the fork stops.  Way back when I had to grind them down to get a decent amount of steering with the Fzr forks.  However I went a little heavy on the grinder, letting the forks touch the tank at full lock.
With the new paint, I wanted to create a more permanent solution, to prevent any dings.
« Last Edit: November 05, 2013, 06:22:01 PM by CB750R »
Offline CB750R
  • 77 CB750F
« Reply #11 on: November 06, 2013, 09:38:21 PM »
I figure I'd try and consolidate this and an earlier thread I had started on this bike.
So here's a few shots I took while redoing the gauges and of the seat I'm STILL WAITING FOR MY WIFE TO RECOVER!!!
untitled-9130.jpg by CB750r, on Flickr
untitled-9159.jpg by CB750r, on Flickr
The seat before and after:
untitled-9032.jpg by CB750r, on Flickr
untitled-9033.jpg by CB750r, on Flickr
Offline CB750R
  • 77 CB750F
I got a box of goodies from Vintage CB750,  a fresh new superbike bar, and some not exactly sexy parts, like a Rick reg/rectifiier, and some new rubber grommets for the side covers, and a rubber tank strap.
But I do have some cool new Photos!!
untitled-9812.jpg by CB750r, on Flickr
The New tail light I installed into the CB750F rear cowl:
untitled-9820.jpg by CB750r, on Flickr
and some more photos of the tank and side cover and front fender, because well I like taking photos!!
untitled-9827.jpg by CB750r, on Flickr
untitled-9816.jpg by CB750r, on Flickr
Offline SOHC Digger
  • I'm not an
Beautiful paint job!
Offline CB750R
  • 77 CB750F
Thanks digger!  I tried painting this thing a few times but was never happy. Glad I sucked it up and paid someone.
This was the first time  I paid someone to work on my bike!
Offline druzli
  • Honda CB750K 1977
    • Gusti photography
Looks promising, subscribed.
“You don’t have to be worried about scratching your bike. You don’t have to be worried about it if gets, you know, dirty. Actually ride it, that’s what it’s made for. We love to make it look differently, but you should also be able to ride it. That’s what it’s all about in the end.” - Nicholas Bech, Wrenchmonkees
Offline brandEn
Nice pictures! Wish I could do that.
That paint and color scheme is awesome.
Offline CB750R
  • 77 CB750F
Re: CB750F2 time to clean up the old girl. Turn Signals!
« Reply #17 on: December 24, 2013, 03:54:18 PM »
Progress Report!
Its been a while, still in physio, its dam cold in my garage, and I've been collecting some new tools!
I picked up a bench lathe from an older fellow that used it for his hobby uses, from what I can see on the lathe he turned brass, plastics and wood, not much hard use on it!
So I figured a good first project is making some new stalks for the rear turn signals.  Here's one of the signals with my stalk attached and the 10mm bolt that I hollowed out allowing the wires to go through.
untitled-5189.jpg by CB750r, on Flickr
Here's a comparison of the mounting stalk thank came with the signal:
untitled-5191.jpg by CB750r, on Flickr
I was able to polish the aluminum up to be a very close match to the finish on the signal body. these will mount on the frame where the grab rail/tool box mount at the back of the bike, and the signals will just be sticking out from the side of the rear cowl.
Offline filipo
  • do I get a jacket for being a
Just catching up with this now, but -- that paint job is hot damn! A really nice idea -- simple but different. Well done.
Offline CB_Jeff
Real nice on the paint, I will be interested to see it all come back together.
If you don't mind my asking, where did you get your tail light?  I like the way it fits the cowl recess and am sure that it will clean up the lines.
Offline CB750R
  • 77 CB750F
Thanks guys the tail surround is from an Autoparts store brand is grote,  it's a stainless truck led light surround. The surround came with a flush led light but it stuck back way too far into the cowl. I had a plastic surround in there before with the light you see in the photo  I originally bought the light from princess auto. (Think harbour freight ).  I used some L channel aluminum to brace the cowl and support the bottom of the light. As well as providing me a place to mount the plate.
I know not some bespoke one of the kind hand crafted tail light off a vintage lake racer... Just some auto and truck parts I figured would look a lot cleaner than the small lunchbox that honda stuck on the back of these bikes.
It's slow going on putting stuff back together as it's dam cold in the garage! And I've been learning to use my new lathe and mini cnc mill in the basement instead of freezing my ass off in the garage!  That and my wife has had my seat in her sewing room for months, awaiting a new cover.
Offline CB750R
  • 77 CB750F
Untitled by CB750r, on Flickr
Here's the test fit of my headlight bracket design.
Offline CB750R
  • 77 CB750F
Here's the first test fit of my new painted body work on the bike.
This bike is reall coming together. The paint came out superb. I really like how the lower line flows to he cowl. The gauges look clean too. Nice!!
Looks to good..
Where you been, we had an awesome meeting at Harry,s in Vernon..last Saturday..
