Author Topic: CB750 Crankcase Ventilation  (Read 2306 times)
Offline banzaibob
« on: November 01, 2013, 07:33:04 AM »
Right now I have the crankcase vent on top of the valve cover vented to a spigot on top of my airbox.  What would be the advantages of putting a pvc valve inline?  What about putting a pvc valve inline and simply running it to atmosphere?  Does anyone have a diagram as to where the stock vent line are suppose to go, oil tank, etc.?
2011 BMW R1200RT
1976 BMW R90/6
1977 Harley Davidson XLCR
1974 Honda CB750
1979 Honda XR/FT500
1976 Honda CB750F
1971 Honda CB350 Diesel conversion
1976 Honda GL1000
Re: CB750 Crankcase Ventilation
« Reply #1 on: November 01, 2013, 07:36:46 AM »
Older models vented to atmosphere via tube from vent to swingarm. Newer models vent to airbox so fumes are ingested by engine and burned.
I see no reason to do anything different.
Offline Bailgang
  • Scott
  • Indiana
« Reply #2 on: November 02, 2013, 03:20:13 AM »
I don't see how putting a pcv valve in the existing vent hose as it is routed whether it be to atmosphere or to the air box will have any effect. The carbs and intakes on our bikes aren't designed for the use of a pcv valve in the first place. My guess is that if you were to use a pcv valve and route it as it typically is for example on a car engine meaning going from the valve cover directly to base of the carb into the intake manifold then your cb750 carbs would then behave as if they had an enormous vacuum leak.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
