Hi Pewe,
This is not at all necessary, but a nice "side effect" since you have a pamco. Pick one of these laser rpm counters off ebay, they are fairly cheap. You can paint the edge of your pamco rotor with black paint (or sharpie), then add a small piece of reflective strip (comes with your counter). With it you can see how far your tacho is out and also do other things like help tune your air screw mixture settings and get idle rpm perfect. Again, none of this is necessary, but these things are cheap for what they are and i'm sure you will find other uses for it around the home if you play with such things.
My tacho (clock) was reading 15% higher than what the digital unit was showing, so nice to know.
Hi Hondaman,
Couldn't agree more that "good engineering practice" means that all things should be kept away from the heat (as the temperature under that points cover is nothing to sneeze at after a hot soak). I can't touch it anyway. Nice that you have some measurements.
The nice things like dyna & pamco is that they are fairly compact and all self contained in the points cavity, so this is convenient. The downside is that the electronics get hot and lifetime can suffer & your 100% on reduced lifetime. We have the 'Arrhenius Equation' which basically says the hotter things get, the worse these problems become.
http://en.wikipedia.org/wiki/Arrhenius_equationThis is the part i wanted to point out as quoted from the link...
"the reaction rate doubles for every 10 degree Celsius increase in temperature." So its an exponential effect.
Your approach of a separate (external) transistorized module away from the points cover wins hands down in this respect. No argument from me & also how i would do it (however with a micro - but thats my field).
Air port tarmac (now that sounds like fun)
