Author Topic: 1977 carb check valve  (Read 1369 times)
Offline iceman321
« on: November 04, 2013, 09:01:41 AM »
Hello
       . I have connected a hose  between Solinoid valve and carb without  a check valve will the bike run without the valve. Just a test run so if the engine will run like a sick dog that is ok thx
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: 1977 carb check valve
« Reply #1 on: November 04, 2013, 11:11:22 AM »
Yes the bike will run without the check.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #2 on: November 04, 2013, 04:23:13 PM »
Yes, it'll run.  But the idle in gear won't behave like it should because of the vacuum pulsations having to suck open the throttle opener repeatedly. The check valve causes the throttle opener to lock wide open after a few vacuum pulses, so the port at the carb is effectively sealed after that.
Stu
MCN DTF
  • Moderator
« Reply #3 on: November 04, 2013, 05:53:24 PM »
+1 Stu.  But for your "test run", it won't matter . . . .
