Author Topic: '76 750k backfire/missing  (Read 674 times)
Offline teembo
« on: November 04, 2013, 10:34:39 AM »
Right outside cylinder back fires a little when  off the throttle, decelerating in gear. Also seems to miss a little when up to speed 3 to 5k rpm.  I've heard this is because it is running lean, true?
Is there a fairly uncomplicated way to adust this?
Offline iron_worker
Re: '76 750k backfire/missing
« Reply #1 on: November 04, 2013, 10:54:32 AM »
How did you narrow it down to just that one cylinder?
IW
Offline teembo
« Reply #2 on: November 04, 2013, 11:06:11 AM »
That pipe rusted out a little bit.  Makes it pretty easy.
Offline Vinhead1957
« Reply #3 on: November 04, 2013, 03:15:05 PM »
Pull the plug and check it for a white electrode.  Then, when confirmed lean look into carb 4.
Offline teembo
« Reply #4 on: November 05, 2013, 05:01:19 AM »
If it is lean, is there a simple way to rich it up?  I know nothing about carbs other than if I so much as touch a screwdriver to one, it runs worse.
