Author Topic: Please help Identify Carb.s  (Read 988 times)
Offline 77Pinto
« on: November 05, 2013, 04:16:32 AM »
Can anyone tell me what these carb.s fit?
I can not find any markings on them other than "Keihin".
Would it be easier to tell from any mearsurements?
Thanks in advance,
Bill
« Last Edit: November 05, 2013, 04:32:26 AM by 77Pinto »
Re: Please help Identify Carb.s
« Reply #1 on: November 05, 2013, 04:23:56 AM »
CB750 1976 or older.
Offline 77Pinto
« Reply #2 on: November 05, 2013, 04:33:22 AM »
Thank you.
BTW: How can you tell?
Bill
Offline lucky
« Reply #3 on: November 05, 2013, 04:33:46 AM »
Return spring in the center .
I would say 1976.
Offline 77Pinto
« Reply #4 on: November 05, 2013, 04:58:39 AM »
Thanks again.
I did a quick search around this site and found a link to a page that says where the numbers are located and what they indicate.  These have "657A"
Bill
« Reply #5 on: November 05, 2013, 05:12:41 AM »
71-76 all had the spring running down the center. Seeing that yours were designed to be used with a #110 main jet I would say they may be from a 73 or so. Here is a little chart for reference. Might want to check that spring closely also as it does not look stock maybe. It looks kinda long and flimsey and a stocker has a rubber sheath on it. See pic and how the stock spring is a little extended at rest. http://www.hondachopper.com/garage/carb_specs/carb_specs.html
« Last Edit: November 05, 2013, 05:23:04 AM by ekpent »
« Reply #6 on: November 05, 2013, 07:59:07 AM »
75 and 76 had a single fuel supply line.
Offline Dream750
« Reply #7 on: November 05, 2013, 08:36:01 AM »
One clue is the idle speed stop screw which is located on the left side of the carb rack in the OP’s first pic. This would suggest that the carbs came off a 1971-74 750 K which had petcock on the right side. The 1975-76 750 K bikes had the petcock on the left side and the idle speed stop screw on the right side. Honda didn’t place the idle screw and petcock on the same side from the factory.
Offline lucky
« Reply #8 on: November 05, 2013, 01:27:10 PM »
I just thought the spring was missing the rubber dampener.
Offline fmctm1sw
« Reply #9 on: November 06, 2013, 04:54:57 PM »
Well...  Now I know my carbs are missing those little boots on top of the little sync nuts.  I kind of thought something was supposed to go there..
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline lucky
« Reply #10 on: November 08, 2013, 11:47:06 AM »
You can skip those rubber boots on top the carbs unless you live on a dirt road in the desert. They just get in the way all the time.
