Author Topic: My Stock to Cafe back to Stock Build  (Read 30745 times)
Re: My Stock to Cafe back to Stock Build
« Reply #100 on: September 03, 2014, 03:18:23 PM »
I used to have an extra spin off adapter made by Terry.
Lesters are one of those things you sometimes get luck with on craigslist or ebay.  I've wanted to use mags for a while, but I want a set of 18" front and rear.
Offline albertaboy
  • No way I'm a
« Reply #101 on: September 04, 2014, 04:06:32 PM »
My bike passed the government inspection today!!!! ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D  Just have to get a license plate now.
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
« Reply #102 on: September 04, 2014, 04:15:37 PM »
Kick a$$!! Congratulations!  Get that plate and ride the bejeezus out of it (at least while you have good weather)!!
Offline albertaboy
  • No way I'm a
« Reply #103 on: September 06, 2014, 04:03:52 PM »
First (of many) shake down run revealed a head gasket leak. If you read my general forum post for help, it must be the 8 o rings I left in between the cylinder and head. When using a Mls gasket, they should be left out.  Every post I read made it sound like an option so naturally, I choose the wrong option. lol.  ;D  I've dove into the repair but It will be about Tuesday before the bike is all back together.
And the forecast calls for freezing temps for Thursday....  :(
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #104 on: September 06, 2014, 06:21:15 PM »
Sounds like you'll get it just right, just in time for winter  :-\
So the good news is: come Spring, you'll be ready to ride!
Bad news: you need a new Winter PROJECT!
How about a 550 this go around?
lol. I'm thinking of studding the tires or maybe I'll consider that snow mobile conversion that showed up on the forum and botm recently.  That thing is  8) cool.
Hey
Anybody know if the MLS gaskets have a proper orientation to up or down. The indents in this one looks more definitive on one side verses the other.  I've seen no instructions.
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #105 on: September 09, 2014, 09:54:39 PM »
If you've followed my MLS gasket leak post, much as been discussed there.
I opened the top end, thankful I installed a frame kit, removed the 8 packing type o-rings and associated dowels. Sprayed my MLS gasket with copper spray, oiled the cylinder studs and torqued them again. Bought a better quality torque wrench so I could feel I had the most accurate reading I could get.  I just came in from the garage after completely reassembling the bike again. I ran it to a full warm up and so far no leak. ;D ;D ;D ;D I really wont get out for a ride until Friday, weather permitting, and that will be the real test.
I also ran out today and officially registered the bike with the Motor Vehicles division. It's officially road legal. Man, I tell you, obtaining a passing safety inspection and obtaining a registration (title) for the bike truly was like getting a trophy.  ;D ;D ;D ;D ;D
1975 CB750K
« Reply #106 on: September 09, 2014, 09:57:37 PM »
Double win on the leak fix and registration.
Offline albertaboy
  • No way I'm a
« Reply #107 on: September 13, 2014, 10:36:39 PM »
So the test ride didn't go well.  :( The leak was as bad. Although I removed the dowels and their packing o-rings, turns out my MLS gasket had the large holes to accommodate the dowels and rings. So go figure. :-\  It was suggested to check the positioning dowels and though I doubted they were the problem, but I couldn't be sure,  I dove back in and checked them to be Ok. I had ground enough off for clearance.  I am the first in the world to have a MLS gasket fail I think.  I can't determine what I've done wrong if I have. As another test, I had removed all o rings, dowels and the gasket and set the head down onto the cylinder and can see no interference that would prevent a good gasket squish.
Now I've placed the paper/fiber type gasket that came with my ebay pistons.  I've put the dowels and o-rings back in, sprayed the gasket with copper coat and torqued to 21 lbs. Tomorrow, I will second torque and put it all back together again.  Crossing my fingers.
Thankfully, I put in a frame kit. :) Thankfully, I have a patient wife as the honey do list is waiting another week.  ;D
Oh, Almost forgot... my head light on/off switch now operates like it should.  It's either a flaky switch or the safety inspector fiddled with it. I'm thinking flaky switch as I'm sure he would have said something.
« Last Edit: September 13, 2014, 10:39:14 PM by albertaboy »
1975 CB750K
« Reply #108 on: September 13, 2014, 10:38:23 PM »
Been there, and I feel your pain.
Offline albertaboy
  • No way I'm a
« Reply #109 on: September 13, 2014, 10:39:50 PM »
Was it a MLS gasket problem?
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #110 on: September 14, 2014, 07:47:27 PM »
Head gasket leak solved.  ;D ;D Put about 25 miles on it and no evident leak. Minor leak coming from the plug recess but I can live with it for now and it will be an easy fix. I will get a bit or riding in before the cold and snow comes.  :)
1975 CB750K
« Reply #111 on: September 14, 2014, 10:24:16 PM »
 Great, hope you get a few rides in yet..
Offline albertaboy
  • No way I'm a
« Reply #112 on: September 17, 2014, 02:28:11 PM »
The weather has smartened up here. Supposed to be nice all week. I chucked the honey do list aside today and plan to tell my wife I was ill and had to lay down  ;D  Worked on a crank seal leak. Put a new one in with Honda bond. I'm not willing to pull the engine, split the cases this year. I had a leak at the alt cover. Pulled that, fresh Hondabond.  Got out for an hour around town. Presto!! No leaks. Even the top end leak from the pucks or cam tower studs has slowed down or maybe sealed up..... idk.  Feeling a bit better now... maybe can find the energy to get back to work.... ;)
1975 CB750K
« Reply #113 on: September 17, 2014, 02:57:19 PM »
You're never too old to play the "sick" card.
Remember to go to the BOTM Voting Thread and post a summary of your build, your trials and tribulations, some before, in progress and AFTER photos.  We all like hearing the "story" behind the build.  Good luck!
« Reply #114 on: September 17, 2014, 03:08:41 PM »
What did you end up doing with the shiny Yamiya Yosh replica pipe?
Offline albertaboy
  • No way I'm a
« Reply #115 on: September 17, 2014, 04:19:20 PM »
Good timing. Plan to post it for sale. Just found a box I think will work for shipping. Will send a PM.
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #116 on: September 17, 2014, 04:52:53 PM »
Will do and Thanks. ;)
Man that bike looks brilliant!!!!!
Thank you Sir!!.  I have received great comments from people like the bike inspector to different friends who are just seeing for the first time since I restored it.  Everybody likes to look at a classic.  Makes it all fun and worth while.
1975 CB750K
Offline BPellerine
« Reply #117 on: September 17, 2014, 05:14:11 PM »
looks good out in the sun !hope it sticks around for you warm in the maritimes.bill
1978 CB 750K ard and webers
another anfob
« Reply #118 on: September 17, 2014, 05:22:19 PM »
So glad to hear you got the leaks fixed.  Now enjoy the heck out of it!!!   8)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« Reply #119 on: September 19, 2014, 07:52:25 AM »
Your K5 came out great,!!!!  8)
Sitting in a RV campground in Anaheim, just noticed in the "see your bike on the road".
 This winter Ill be turning my K6 into complete stock, the bikes are so good looking to me in stock form.
 Ill be trying my hand at painting tank and side covers Candy Antares Red, wish me luck.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline albertaboy
  • No way I'm a
« Reply #120 on: September 19, 2014, 08:33:26 AM »
All you need is tenacity, rather than luck. But good luck anyways.  :)  Thanks for the props. For a classic bike, I agree its a great bike stock. I'm really pleased how it turned out. Mind you, I hired pros to get thinks like the tank and covers sprayed properly, the head machined properly so I think I just bolted it all back together. Even the carbs are simple devices.
Mine attracts attention and some good conversations. People are amazed how new it looks. All I can say is get started and don't look back.  ;D
1975 CB750K
« Reply #121 on: September 19, 2014, 12:30:06 PM »
I must agree that my stockish 550 has a great nostalgia value -- so much so that I will keep that bike and not do any further major mods.
Anaheim -- right down the road from me.  Camping in Anaheim??  Where?  At Disneyland or the Big A?
Offline rtbmrgl
« Reply #122 on: September 20, 2014, 08:32:33 PM »
Well I live in No Calif, wife and I were visiting our grand daughters, 3 and 1, we stayed at Orangeland RV park., right next to A's stadium and Honda center. Had a great time, little on the hot side, :o
thanks, Mark
Roseville, Ca
Got Points!
« Reply #123 on: September 23, 2014, 02:43:01 PM »
Thankfully, we made it through a hellish heat wave, combined at times with some high humidity from storms off the coast of Baja California. It was excruciatingly unpleasant.  On top of it, I had to go out to Palm Desert two weeks ago when it was 115+.  YUCK!  I like our typically warm weather, but I'm glad the heatwave is over.
