Author Topic: My Stock to Cafe back to Stock Build  (Read 31356 times)
Offline Ravie
  • Definitely not a
  • Soul to Soul
Re: My Stock to Cafe back to Stock Build
« Reply #75 on: August 13, 2014, 06:07:19 PM »
How cool is it up there?  Surely it isn't getting cold yet..
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline albertaboy
  • No way I'm a
« Reply #76 on: August 14, 2014, 03:48:53 AM »
Haha, It isn't getting cold yet. We're getting 75-80 F temps right now and it looks like it will last for a while yet.  I was feeling pretty defeated yesterday but I'm feeling optimistic I can reverse my mistake pretty quick. It looks like the shifter's C fork didn't fall into place. I've put every free second I had this past month, thinking I would have the bike ready to fire, tune, get safety inspected, insured and start riding and break in.   All before my kid moves back in ( have to build storage and clean out his room) and then start running my 82 yr old mother to medical appointments (starting chemo in Calgary - a 3 hour drive one way). I figure by the time I get through this and get back to the bike,  6 weeks will have gone by and... brrr, those 80 degree days are long gone.  That is all I meant.
Anyways.... optimistic that I will find some time here. After a Pm with Hondaman, I understand the C fork can easily not go into place if one isn't careful and know to double check it. I didn't know and didnt check it.  So no crying just get doing.   I'm having a quiet moment at work right now, 430 am and I don't get home for another 3 hours.  I really dislike my shift work schedule these days. Getting to old for it.  I hope next Wednesday Thursday days off will find the time to fix this. I'll post pics if I remember to stop and take them.  This is all part of the build I guess. Cheers and thanks for following along.
1975 CB750K
No where to go and all day to get there.
My build thread: http://forums.sohc4.net/index.php?topic=131424.0
Offline albertaboy
  • No way I'm a
« Reply #77 on: August 14, 2014, 03:28:18 PM »
I'm envisioning a sidecar with a heated seat and windscreen for your Mum as you drive her to and fro to the treatments? Might be just what her blessed heart needs, a little soul uplifting to endure the discomfort?
Either way, we will say a little prayer for her, and for you with the trans. Good on you for keeping the priorities in order. Your bike will survive some separation time from you when your family needs you more.
Lol.  Thanks for the well wish but especially, thanks for cracking me up. That was funny.   ;D
I woke up at the crack of 1:30... that's right, PM and figured I could get a couple hours in before heading off to work again. I started lightening the bike to flip it on it's side to pull the motor. Man I can disassemble. Things always come apart way faster than it went together.  Sorry no pictures but who wants to look at that anyways. I'll update again, likely not til I've confirmed my transmission problem and am re-building again.  Cheers. ;)
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #78 on: August 18, 2014, 04:57:06 PM »
So... small up date. Pulled the engine prepared to split the cases expecting to find the transmission C fork out of place. I did not get that far. Before splitting the lower cases, the counter shaft retainer had to be pulled away.  Just pulling the retainer away from the counter shaft bearing released what ever was binding inside the transmission.  Kinda confusing how on earth that could happen but whatever, the transmission now works like it should and I am putting the bike back together again.... ;D
1975 CB750K
Offline Ravie
  • Definitely not a
  • Soul to Soul
« Reply #79 on: August 21, 2014, 08:01:57 PM »
Awesome! Much mojo your way!
Sent from my HTC One V using Tapatalk
Offline albertaboy
  • No way I'm a
« Reply #80 on: August 21, 2014, 09:02:17 PM »
Thanks for the mojo Ravie
Well, I burnt the midnight oil a couple nights and I got back to where I left off and then some. Carbs and exhaust now installed.  Tear and down and reassembly went way faster than I imagined (Third time to take this bike apart). Although, it's still a lot of work or so it seems and I was afraid to dinging the paint here and there.
I bit the bullet and went with Yamiya "no numbers".  Those no-no's are Yes-Yes!!. I like em. Easy peasy install.
I had rebuilt my carbs 3 years ago and there's only 300 miles on them. New o-rings, any rubber- ie gaskets, air idle springs,  New jet needle and seat, float jet.. all Honda OEM. This time, I dropped the jet needle clip one notch, replaced the 110 main jet with 115's but left the slow jet at 40.  Cleaned with Honda's own carb clean.  We'll see how this goes.
Now, I've got a signal light, head light wiring issue to figure out.... but firing this has to wait until Monday  :(
« Last Edit: August 23, 2014, 03:46:43 PM by albertaboy »
1975 CB750K
Offline Trad
« Reply #81 on: August 22, 2014, 01:37:45 PM »
So Clean!
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline albertaboy
  • No way I'm a
« Reply #82 on: August 23, 2014, 03:45:10 PM »
So Clean!
Thanks Jared. Yeah, kinda cool to see it look so new like.  It's going to be Friday before I've time to fire it. Can't wait but nervous too.
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #83 on: August 30, 2014, 11:55:20 AM »
So it's true they're only original once but they can look new twice.  Here is some back alley glamor shots of the completed bike then I took it out for a short road test around the block.
I had a timing challenge that I over came with a little help from my forum friends. Thank you boyz. I had to pull the carbs and re bench sync to bring the idle down. The test ride put a smile on my face. She pulled decent to 5000 rpm where I shut it down. I read to ride em hard to break in but I wanted to stay away from Red line today. I have to get a provincial govt inspection next but also figure out why my signal lights are not working as well. Here's some shots. Thanks for following along. Cheers
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #84 on: August 30, 2014, 12:05:56 PM »
Really beautiful bike, AB. You must be grinning so wide you look like Jack Nicholson in Batman!
lol. Maybe a little wider even...  ;D ;D ;D
1975 CB750K
« Reply #85 on: August 30, 2014, 01:49:51 PM »
Gorgeous bike, AB. I don't necessarily think you need to keep it below 5K during break in, but obviously no need to run it near RL either.
Stunner!
Offline albertaboy
  • No way I'm a
« Reply #86 on: August 30, 2014, 02:08:26 PM »
Thanks boys
Cb racer fan.  Good to know. Thanks. :)   I planned to follow the " on the street" procedure in this link.  Should do the trick??
http://www.mototuneusa.com/break_in_secrets.htm
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #87 on: August 30, 2014, 02:24:22 PM »
Here's a reminder from Oct 2010.  Kinda hideous in comparison
« Last Edit: August 30, 2014, 02:35:18 PM by albertaboy »
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #88 on: August 30, 2014, 04:45:06 PM »
This :)
This  ???
Or this   ;D ;D ;D
1975 CB750K
« Reply #89 on: August 30, 2014, 04:51:23 PM »
I like both options/results 2 and 3.   ;D
Frankly, it only matters what you like best, right!?
The bike will hold more value long term in its stock configuration.
Offline Tews19
  • I am no
« Reply #90 on: August 30, 2014, 08:33:12 PM »
BOTM nomination!
1970 Honda CB750 survivor.
Offline albertaboy
  • No way I'm a
« Reply #91 on: August 30, 2014, 08:46:21 PM »
What you like best is So true. I didn't finish my BCR creation and painting the tank and covers would have made a big difference. Frankly, the seat, despite the progressive shocks, did not give my old spine enough protection. I took a couple bumps that sent a jolt from my arse crack to my hair line that was pretty uncomfy.  ;D
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #92 on: August 30, 2014, 08:59:33 PM »
BOTM nomination!
Seriously?  That's really cool. I could say it's finished for this year at least but they're never really finished. I've plans to upgrade wheels being either restored Lesters or SS spokes and aluminum rims but I've run out of time til next year. I always vote too.  Was a hard choice this month.  Well thanks if you nominate.  :)
1975 CB750K
« Reply #93 on: August 31, 2014, 08:06:21 AM »
I'm holding that nomination until October's open!
I'll second it.
Offline albertaboy
  • No way I'm a
« Reply #94 on: September 01, 2014, 11:34:02 AM »
I'll second it.
That's cool guys.  Thanks for the kind words. I am almost ready to accept.
When putting my signal lights on, I overcame a ground issue, then a loose connection issue and got them working. When the brakes went in, the levers lit the tail light like they should. Then the dash board went in no problems. Last was the head light.   All of these functions tested and worked independently of each other until my inaugural ride, around the block, a couple days ago when I turned on the headlight switch to discover my signal lights wouldn't flash but also my headlight and taillight flashed with the headlight switch off.  No big deal I thought. All that color coded goodness mashed behind the headlight just needed a quick go over and re-plug the right color that I must have screwed up. lol.  Nope, not that easy.
Basically, I posted on the general forum which led to a bunch of good ideas and I've resolved 99% of the problem. The headlight doesn't switch off. It's on ful time when the bike is running.  I  have to get a government safety inspection next and before I can get a license plate.  These guys can be real sticky and I don't have any bribe money (j/k) I'll continue to work on this issue but I might call, explain the problem and see if they care.  Today is a Labor day holiday and I can't arrange the inspection til tomorrow. Hopefully, Im not looking at a two week wait.
« Last Edit: September 01, 2014, 03:50:54 PM by albertaboy »
1975 CB750K
Offline albertaboy
  • No way I'm a
« Reply #95 on: September 01, 2014, 04:04:25 PM »
Did it switch "Off" previously? Lots of bikes have an always "on" wires system, only interrupted during start to minimize the drain on the electrical system.
I can't remember. I didn't get much time on it to become familiar. At this point, it is a switch that doesn't function at all I am sure the inspectors won't ignore it.  I would like it to work correctly regardless and I don't expect I'll get an inspection booking so quick that I can't get back out for a look.   Lol, I could still argue it's a custom feature, that doesn't affect anything safety wise  ;D  Im sure rat rods and customs have been brought in from elsewhere that pass inspection.  We'll see.
1975 CB750K
« Reply #96 on: September 02, 2014, 02:18:48 PM »
Alberta,
Are you using the Cycle X spin on oil filter?  If so, what type of filter are you using?  It looks different than the one that came with my rig.  I think their set up uses a Harley size filter.
Offline albertaboy
  • No way I'm a
« Reply #97 on: September 03, 2014, 02:15:44 AM »
Alberta,
Mine did not come from Cycle X. An ebay seller some time ago. I can check that filter when I get home but having just checked the cycle x site, the two adapters look completely different.
1975 CB750K
« Reply #98 on: September 03, 2014, 10:00:21 AM »
Thx.  It could have been made by Terry - I believe he used to make them as well.
Have you already sourced a pair of Lesters?
Offline albertaboy
  • No way I'm a
« Reply #99 on: September 03, 2014, 03:12:45 PM »
That filter is a QS3614. It measures 3 inches across if it's just a matter of ensuring the rubber sealing lip will contact. It might of been Terry's. I think it came from an USA address though. I can't find the paperwork for anymore.
I'm still keeping my eye open for cb750 Lesters. Any ideas?  :)
1975 CB750K
