Author Topic: CB500 air filter hold down, part # 17216-323-020  (Read 8204 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: November 06, 2013, 01:19:02 PM »
SPRING, A/CLNR ELEM
OEM part # 17216-323-020
       Here is a part I made for the air filter element to stay in place.  I could not find one so I made it.
I used piece of aluminum and a old trowel, you can also use spring sheet metal. Bend the spring as shown, use rivet or screw to hold on spring.
 84mm L  X 14mm W
Maybe I'll go into production,  ;D
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline natron602
Re: CB500 air filter hold down, part # 17216-323-020
« Reply #1 on: January 05, 2015, 07:58:16 PM »
I just jammed a plastic oil cap in mine.
Offline rtbmrgl
« Reply #2 on: January 05, 2015, 09:03:07 PM »
wow, it only took 1 year and 2 months to get response,  ;)
 I forgot I posted it
thanks, Mark
Roseville, Ca
Got Points!
Offline natron602
« Reply #3 on: January 05, 2015, 09:04:16 PM »
I thought you deserved validation.
Offline rtbmrgl
« Reply #4 on: January 06, 2015, 12:29:25 AM »
thanks,
thanks, Mark
Roseville, Ca
Got Points!
Offline Grump
« Reply #5 on: July 13, 2016, 03:59:25 PM »
Old topic but.... Nice fix.
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #6 on: April 11, 2018, 01:15:38 PM »
