Author Topic: 78' 550k w/Clubmans  (Read 1801 times)
Offline redrider736
78' 550k w/Clubmans
« on: November 06, 2013, 02:52:24 PM »
Wanting to put a set of Lossa Clubmans onto my 78' CB 550k. Will my stock front brake, throttle, and clutch cables be too long ?? Do I need to replace ?? If so with what ??
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-handlebar-parts-lossa-engineering-chrome-clubman-handlebars-le-club-c.html
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline wowbagger
  • Not much of an
Re: 78' 550k w/Clubmans
« Reply #1 on: November 06, 2013, 06:34:52 PM »
Yes, the cables and brake hoses will be too long. I believe that you can get motionpro cables on custom lengths. As for brake hoses, I prefer the braided hoses Slingshot Cycles makes but just about any hudraulics shop could make up a hose for you. You'll also want to check your master cylinder on the new bars to make sure that it doesn't sit at too sharp an angle and let air in the line.
Offline redrider736
« Last Edit: November 06, 2013, 07:45:09 PM by redrider736 »
Offline wowbagger
  • Not much of an
« Reply #3 on: November 06, 2013, 09:57:21 PM »
That's roughly the length you'll want but that specific cable won't fit your 550, as far as I can tell. Here's the stock cable length for reference:
http://www.dimecitycycles.com/vintage-cafe-racer-caferacer-bobber-brat-chopper-custom-motorcycle-cables-honda-cb550-throttle-cable-02-0155.html
If you are doing a DCC order anyway, I'd just give them a call. They'll be able to tell you the right cable your 550 needs for the clubmans.
I actually ended up just leaving my throttle, clutch and tach cables the stock length. I did get the shorter brake line though. There is a bit of excess cable below the headlight but I don't think it looks too bad. At least, I don't think its woth the $75 for shorter cables.
Offline redrider736
« Reply #4 on: November 07, 2013, 10:12:16 AM »
Like the looks of your set up !! thats what I am after.
What yr is your CB and  what model of clubmans are you running with ??
ThX
Offline wowbagger
  • Not much of an
« Reply #5 on: November 07, 2013, 10:24:09 AM »
That's a 1971 CB500. Not sure what brand clubmans those are since they came with the bike.
Offline redrider736
« Reply #6 on: November 07, 2013, 12:54:01 PM »
Great info !! ThX..
Offline redrider736
« Reply #7 on: November 08, 2013, 09:17:01 AM »
Found a set of Clubmans I think I am going to pull the trigger on and order them up.
I like the adjustability built into them ..... and they LQQk pretty sweet as well.
Set to order up new shorten brake lines from Slingshot Cycles, and going to wait and see if the stock clutch/throttle cables will work?
http://www.guzzino.com/tococlba.html
« Last Edit: November 08, 2013, 09:21:09 AM by redrider736 »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #8 on: November 08, 2013, 11:11:56 AM »
Check out these {http://www.omarsdtr.com/club11.html
Half the cost of the Tomaselli's
Offline Bankerdanny
« Reply #9 on: November 08, 2013, 11:13:10 AM »
I also really like the look of Norman Hyde M bars. Several people here have them on their bikes
Offline Bankerdanny
« Reply #10 on: November 08, 2013, 11:16:12 AM »
Check out madScientists 750 Cafe with the M bars: http://forums.sohc4.net/index.php?topic=113293.msg1424744#new
Offline wowbagger
  • Not much of an
« Reply #11 on: November 08, 2013, 11:18:38 AM »
+1 to the M bars. My clubmans are starting to rust in a couple spots. When then get replaced it will be with the M bars.
Offline redrider736
« Reply #12 on: November 08, 2013, 12:13:27 PM »
WoW, Nice ! ThX
