Author Topic: Replacement "tongued washers" for rear wheel CB750?  (Read 2901 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: November 07, 2013, 01:36:29 PM »
So these are the two curved pieces that go between the sprocket and the lug nuts, with the tabs that bend up to keep the nuts from backing off (p/n 94108-17000). They're no longer available, so what do y'all use when replacing a rear sprocket?
Re: Replacement "tongued washers" for rear wheel CB750?
« Reply #1 on: November 07, 2013, 01:41:11 PM »
make your own or safety wire them.
Wobbly
« Reply #2 on: November 07, 2013, 01:56:49 PM »
Are you sure Honda doesn't carry them anymore? I find that hard to believe. In the meantime: http://www.cmsnl.com/honda-cb750f-750-super-sport-1976-usa_model490/washer-a7-tongued_9410817000/
Offline KayOne
« Reply #3 on: November 07, 2013, 01:59:35 PM »
David Silver Spares have them at a reasonable price. Great customer service.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #4 on: November 07, 2013, 02:36:29 PM »
I just use Loctite 262/263 and have had zero issues. I remove my sprocket for gear changes pretty often, and the Loctite does it's job perfectly. Just a little dab is all you need.
If you want the original configuration, disregard this post.
Follow my build "P38 Racer" in Project section
« Reply #5 on: November 08, 2013, 05:30:51 AM »
I use nylocks, trust them more than reused washers.
Wobbly
« Reply #6 on: November 08, 2013, 05:37:31 AM »
Well, you are not supposed to reuse them. I believe they are about 1 or 2 $ a piece. And since they are quite visible...
Wobbly
« Reply #8 on: November 08, 2013, 06:24:49 AM »
A little pricey? CMS in the Netherlands is usually very expensive, but they only charge 1 Euro ($ 1.33) a piece. The best bet is the dealership. I am sure that they are still available. I always check Honda first. There is nothing better than the real thing :)
« Reply #9 on: November 08, 2013, 06:35:23 AM »
I am sure Honda would use modern means of locking nuts if it existed back in the day.
I prefer to improve where I can - for example electronic ignition is better than the real thing such as points.  Just saying  ;D
Wobbly
« Reply #10 on: November 08, 2013, 06:45:25 AM »
Don't be fooled: I have electronic ignition, steel brake lines, and the Konis aren't from Honda either. :)
The tongued washers come polished, work fine, and look pretty nice against the black sprocket plate/cover. That's all.  :D
« Reply #11 on: November 08, 2013, 06:45:57 AM »
And how much for shipping to Nashville??
Wobbly
« Reply #12 on: November 08, 2013, 06:53:40 AM »
Like any mail order, it isn't worth it to have a 1$ shipped--which is why I suggest the local Honda dealership. But if you really need a part from Europe, I could help out. I only pay domestic postage from Germany to the continental U.S., being at zip 09180.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #13 on: November 08, 2013, 07:19:56 AM »
Not if it breaks down on the road, I have been seriously considering going back to points and the Hondaman points amplifier.
Much easier fix when all you usually need is a condenser or a point and point file.
With electronic you are up $hit creek until you get a replacement unit.
« Reply #14 on: November 08, 2013, 11:31:08 AM »
Yamiyas got them in a set with the disc brake washers and nuts, for about $8. Usually about $18 S&H from Japan. Usually 3 days to Indiana. IF you can find another of their really cool trinkets to buy it may make it worth it.
