Author Topic: CAFE Folks-CB350 twin pistons;I want O.E. 66-67mm & 10.5:1 compression...  (Read 4337 times)
Offline grcamna2
Not a sohc4,I know  ::) ;I tried on hondatwins.net but, no action on that site...,but still hoping to research this question here on my favorite forum.
I want to find a pr. of stock O.E. pistons from any of the Big Four(Honda,Kaw.,Yam.,Suz.)that'll let me simply bore out my cylinder liners to accept either 66-67mm,up from the stock 64mm & 9.5:1 of the CB350 twin.
I'm asking if anyone here has ever done the research to find the correct pistons to achieve that 10.5:1 compression ratio(no higher)and w/o having to do lots of extra machine work other than just boring out the cylinder liners,etc.I don't plan on ever using a high lift cam(maybe a slight .020-.030 lift mod. only w/ a custom grind to my stock CB350 twin camshaft) as this will be a street use bike only.I want a little more grunt for climbing,etc. for when I load the bike up w/ more weight.I like this little bike and don't want to keep it parked.
I know there aren't too many folks who may have thought of using an O.E. piston from another manufacturer to accomplish this but,I think O.E. pistons & rings are very satisfactory & will make her work Best for me.
If any of you members have thoughts or experience on this that'll help,please feel free to PM me or just post here so I can get some help with this research.
I was told a pr. of KZ440 pistons may work... Any thoughts ?
        Thanks, grcamna2  :)
« Last Edit: November 11, 2013, 01:40:07 PM by grcamna2 »
Offline grcamna2
Re: CAFE Folks-CB350 twin pistons;I want O.E. 66-67mm & 10.5:1 compression...
« Reply #1 on: November 11, 2013, 01:41:45 PM »
bump
Offline grcamna2
« Reply #2 on: November 14, 2013, 08:07:01 AM »
bump
Offline madScientist
« Reply #3 on: November 14, 2013, 08:37:21 AM »
I have a CL350 but I think the pistons are the same. I know folks used the 350 pistons to make 836 kits in the 4's but not vice versa. The 350 pistons were high dome pistons whereas the 750 pistons were not. It is possible to use 750 pistons but I think you're going to have to dome some surgery to get the compression ratio high enough to add any benefit. As to other makes I'm not sure either. The KZ pistons would likely be no good as they were flat top or slight domed. Suz's and Yami's i've never seen.
I've done a little research on the 440 pistons but not enough to warrant me speaking towards them. You might be better off going to bore-tech and picking up a set of their pistons. That is what I will be doing for mine.
You CAN do great things...with enough beer.
78 cb750f
http://forums.sohc4.net/index.php?topic=113293.0
70 CL350 Street Tracker / Cafe
http://forums.sohc4.net/index.php?topic=125641.0
83 KZ1100ltd
76 GL1000
71 Kaw H2 (to be built)
77 cb750A (sold)
74 cb125s (sold)
Offline grcamna2
« Reply #4 on: November 14, 2013, 09:09:01 AM »
Hi there you madScientist,
      I have a pr. of Boretech's 65mm cast pistons(cheap Chinese cast pistons w/ cheap rings)that come w/ wrist pins,clips,rings..,etc. but haven't installed them just yet.I've been on the phone w/ Kelly about a pair of chrome replacement rings that Bill can get that I would rather use to install these pistons for longer ring life.
I've had my cylinders bored out to fit these pistons by an Excellent machine shop in CO. and they used such a nice,fine finish hone that I look forward to installing the "O.E. style" chrome rings from Boretech once I purchase them.The finish of the bore job being done w/ fine stones is essential for proper break-in w/ chrome O.E. type rings.These Chinese pistons are only 9.5:1(same as stock) and I want just a little more..;but not as much as 12:1 such as that great set of forged Boretech 67.5mm racing pistons. I want a "street only" set up.
I'm still interested to do more research about the larger bore O.E. pistons that I can swap from another make/model to achieve my desired 10.5:1 compression ratio.
I'll just keep researching and possibly speaking to a few Café racers who've built different CB350 twins...
Thank You for your feedback madScientist  ;)   Bill grcamna2
« Last Edit: November 15, 2013, 12:28:37 PM by grcamna2 »
Offline grcamna2
« Reply #5 on: November 15, 2013, 12:32:15 PM »
Has anyone ever installed a pair of Kawasaki KZ440 67.5mm O.E. Std. pistons into a Honda CB350 twin that you know of ??
I'm wondering if the piston pin is the same size ?
Offline grcamna2
« Reply #6 on: November 16, 2013, 08:49:05 AM »
bump
Offline FuZZie
« Reply #7 on: November 16, 2013, 02:45:50 PM »
Wish I could help, your not getting any replies. Someone must have done something like this.
Offline BAchvytrk
« Reply #8 on: November 16, 2013, 05:52:30 PM »
i have 4 or 5 old kz 400 and kz440 motors here. i don;t have any tore down but i could and get you the pin measurement.  pm me tomorrow to remind me, i'll be workin in the shop all day.
71 FLH
74 Ironhead
1965 305
1971 SL350
1974 750k
1975 550F
1977 550K
1980 KZ440
1980 CB900F
Offline grcamna2
« Reply #9 on: November 18, 2013, 01:15:18 PM »
PM sent
Offline bj
« Reply #10 on: November 18, 2013, 03:49:49 PM »
I just got Wiseco 66mm forged pistons for my 350. Compression ratio is 10.5 to 1. Haven't got them installed yet though. It another one of my many winter projects.
You might try posting a question on caferacer.net. Lots of real 350 knowledge there.
« Last Edit: November 18, 2013, 03:51:46 PM by bj »
CB550K1, CB350K4, CB350K4 race, '81 Passport
Offline grcamna2
« Reply #11 on: November 19, 2013, 02:12:42 PM »
thanks bj !
Offline grcamna2
« Reply #12 on: November 21, 2013, 01:55:00 PM »
Terry,
     I appreciate your PM & email  ;) I hope you and Yours have a Great Thanksgiving !
Offline grcamna2
« Reply #13 on: November 26, 2013, 05:09:31 AM »
Have any of you given this piston swap a go w/ your CB350 twin ???
                                            PM's Welcome  :)
Offline grcamna2
« Reply #14 on: November 26, 2013, 10:37:45 AM »
I just learned that the KZ440 pistons won't work because of the height of the piston dome in relation to the wrist pin.
Offline grcamna2
« Reply #15 on: November 28, 2013, 02:28:23 PM »
Anyone have any other idea's on O.E. Japanese motorcycle pistons that'll swap in to my CB350 twin ??  ???
Offline grcamna2
« Reply #16 on: December 05, 2013, 01:39:39 PM »
Anyone ???  ::)
Offline kpier883
  • is quite the
« Reply #17 on: December 05, 2013, 02:25:12 PM »
What size wrist pin holes are in the stock CB350 pistons?
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline kpier883
  • is quite the
« Reply #18 on: December 05, 2013, 02:31:41 PM »
Yamaha XS400 has a 69mm bore...  I don't know anything more about them though...
« Last Edit: December 05, 2013, 02:51:45 PM by kpier883 »
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline grcamna2
« Reply #19 on: December 06, 2013, 01:11:34 PM »
kpier,
   They're 15mm.  :)
                Thanks
Offline grcamna2
« Reply #20 on: December 11, 2013, 11:25:16 AM »
bump
Offline kpier883
  • is quite the
« Reply #21 on: December 12, 2013, 08:03:48 PM »
A little searching turned up these specs for KZ400 pistons.
Cylinder Diameter: 64.0 mm
Piston Length: 61.5 mm
Compression Height: 25.3 m
Dome Height: 9.7 mm
Wrist Pin Diameter: 15 mm
Wrist Pin Length: 53.5 mm
Fwiw...
74 CB750
80 CBX
82 KZ1000 K2 (LTD)
57 1/2 ton chevy
Offline grcamna2
« Reply #22 on: December 18, 2013, 12:10:12 PM »
THANK YOU VERY MUCH kpier883 ! I'm many steps closer now in research  ;) :)
I wonder if KZ440 pistons have similar dimensions except for the 67.5mm bore ?
« Last Edit: December 18, 2013, 12:16:03 PM by grcamna2 »
Offline grcamna2
« Reply #23 on: December 28, 2013, 11:39:42 AM »
I just moved my storage/tools,etc. into this new area..,but when I can,I'm going to look at the 81-82' model year Kaw. KZ750 four piston and see if I can match it up to my CB350 twin piston...;from what I've been reading on other forums it could be a direct swap. I Hope so  ::) !
