Author Topic: Possibly a dumb carb question.  (Read 781 times)
Offline Jayelwin
« on: November 10, 2013, 06:12:01 PM »
So I've got my carbs ready to be either bench synced or installed. If I am going to do a vacuum sync with my manometer do I need to do a bench sync - my eyeballs show a pretty consistent gap across the 4. And I'm going to be messing with the adjusters anyway when it's running during a vacuum sync.
And if I should do a bench sync, do I do it from the air box side of the carb or the engine side of the carb (measure the gap, that is).
-Josh
Re: Possibly a dumb carb question.
« Reply #1 on: November 10, 2013, 06:18:22 PM »
Eyeball will probably be close enough to run. If you have had the adjusters apart make sure there is still enough headroom in the slides to allow the idle adjustment knob or screw to still work.
Offline Hannibal Smith
  • 3rd Grade Dropout
« Reply #2 on: November 10, 2013, 06:24:22 PM »
I agree. An eyeball sync will get you started. If you are a gun enthusiast, then I would trust the eyeball technique, but if you are a vegan peacefreak, then you might want a second opinion.
Follow my build "P38 Racer" in Project section
« Reply #3 on: November 10, 2013, 09:09:09 PM »
;D
Get on with your vac sync...
Offline Deltarider
« Reply #4 on: November 11, 2013, 06:19:14 AM »
Am I the only one that doesn't understand?
CB500K2-ED Excel black
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #5 on: November 11, 2013, 08:06:58 AM »
It's more of an "ironic" comment coming from a guy on the California coast. I'm sure he is alone in his thinking where he lives but feels the need to make sure people know his opinion.
To answer the OP as long as you can get the bike running good enough to do a vac sync, eyeballing it is good enough. If not then you may end up pulling the carbs again to reset them. Keep that in mind.
« Last Edit: November 11, 2013, 08:08:56 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Mo
« Reply #6 on: November 11, 2013, 08:24:24 AM »
A bench sync also takes all of 5 minutes to do..
