Author Topic: Kickstart suddenly not working  (Read 537 times)
Offline hughes1962
« on: November 10, 2013, 06:30:19 PM »
What would make the kickstarter suddenly not work? When I got the bike it worked great and did so the last time I tried it. This morning when I pushed it through it felt about the same as it would with the spark plugs out but it started right up with the electric starter. Thanks for any guidance you can give me.
Offline Powderman
Re: Kickstart suddenly not working
« Reply #1 on: November 10, 2013, 06:31:52 PM »
What bike is it?
Offline Dr. Noisewater
« Reply #2 on: November 10, 2013, 07:15:03 PM »
Did you have the clutch pulled in? I had the same scare then realized I was holding the clutch..
Sent from my iPhone using Tapatalk - now Free
Offline hughes1962
« Reply #3 on: November 11, 2013, 09:25:21 AM »
Thanks for the tip but Good Gosh I must be the stupidest person on the planet!
I was trying to trace the source of a noise and had put a zip tie around the left grip and clutch lever to hold it in so I could listen to the engine running with the clutch lever pulled in... and I completely forgot it was there. Clipped it off and surprise, surprise - the kick start works like new.
(I swear I wasn't drinking and I'm not on medications - although after this, maybe I should be...) Thanks guys... once again - saved by the SOHC Forum!
PS: it's a '71 CB500 - should have mentioned that in the first post.
Offline 74750k4
« Reply #4 on: November 11, 2013, 12:18:15 PM »
As long as I'm in neutral, my kickstart works the same, whether the clutch is engaged, or not!  What am I doing wrong???
Offline 72_350_FOUR
« Reply #5 on: November 11, 2013, 12:49:34 PM »
I think if it's in gear and the clutch is in it wont work.  I learned this in the middle of traffic one day, after stalling the bike. haha.
1972 Honda CB350F
