Author Topic: FOR SALE - A Parts/Bikes  (Read 30478 times)
Offline 122JG
Re: FOR SALE - A Parts/Bikes
« Reply #75 on: July 07, 2016, 07:07:05 PM »
do you still have the kick start lever ?
Offline NashG
« Reply #76 on: July 23, 2016, 11:23:37 AM »
Hi I have a 1978 cb750 A I'm looking for the back grab bar for it. Anybody have one they're wanting to sell or know someone?? Thanks
Offline dperl
« Reply #77 on: July 23, 2016, 07:19:47 PM »
I'm actually looking for one too^ If anyone has a couple..
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #78 on: July 23, 2016, 07:57:02 PM »
can you show a pic of one?
Offline NashG
« Reply #79 on: July 24, 2016, 07:36:41 AM »
Should be something like this one cause I'm pretty sure the back blinkers mount into it
« Last Edit: July 24, 2016, 07:38:26 AM by NashG »
Offline NashG
« Reply #80 on: July 24, 2016, 07:50:56 AM »
You can kind of tell in this picture how the blinkers go into the bar
Offline Jdensmore
« Reply #81 on: July 26, 2016, 10:07:37 AM »
Anyone have some decent exhaust systems for a 77?
Offline 122JG
« Reply #82 on: July 31, 2016, 12:13:03 PM »
anyone shopping for a new seat ?
I've got one from a '76 that has been professionally re-upholstered, with absolutely no rips or imperfections.
seat pan is rock solid and very clean, with no hint of rust or corrosion.
PM me for details...
Offline kac3177
« Reply #83 on: October 17, 2016, 07:47:10 PM »
You still have the exhaust? Price and condition?
kac3177
  • Gusto mo titi ko?
    • project
need a good set
« Reply #84 on: November 18, 2016, 06:43:55 AM »
of side cover grommets
Offline treetrimmer
  • 72 CB750 Hot Rod Styled
« Reply #85 on: February 20, 2017, 07:30:26 AM »
Looking for a parking brake cable assembly and the small plastic diaphragm with the vacuum lines that is attached to the carbs. Had a small engine fire and these 2 pieces got damaged (fuel line split).
Thanks,
Jeff
More Honda Fun All The Time!
Offline Feragos
« Reply #86 on: June 27, 2018, 07:56:03 AM »
Complete engine, minus carbs and insulators, off a 1978 CB750A. Turns over with electric starter.  I bought it 3 years ago for the carbs and insulators. Figured I use it someday, but now it is time for spring cleaning. The guy I bought it from said it was in a barn for many years and needs an upper gasket set, oil pan gasket and the valves cleaned and seated. Located in Northern Illinois about 30 miles NW of Chicago. Local pick by you and your shipper.
VIN# B750AE-72022xx   Make a reasonable offer and it is yours!
Saw the complete gasket set on E-bay for $74.99 http://www.ebay.com/itm/Honda-CB-750A-1976-1977-1978-Full-Gasket-Set-Kit-CB750A-Hondamatic-Automatic-/400702361642?pt=Motorcycles_Parts_Accessories&hash=item5d4bb8d02a&vxp=mtr
Hi, do you still have it? I need the stator cover only if it is in good condition. Thanks.
Sent from my SM-N950U using Tapatalk
Offline devon125
« Reply #87 on: November 17, 2018, 02:53:06 PM »
 1977 hondamatic 750cc looking for a camshaft,  I read the shaft on the "K" series works with the 77 Hondamatic as well.....anything out there?
Also looking for a camchain tensioner adjuster for same...
Offline wingedwheel
« Reply #88 on: November 27, 2018, 03:29:40 PM »
Hi all,
Looking for a seat or pan from a '78, also the rear bar for the blinkers.
Thanks
Offline dave the welder
  • dave the welder
« Reply #89 on: November 30, 2018, 05:20:56 AM »
got one for a 77 they should be the same.where you located
don't buy it build it
« Reply #90 on: January 06, 2019, 10:42:13 AM »
 A local shop has a Hondamatic for sale, I think he's down to $1200 for it, runs and rides good. Charlies Cycle Supply, West Jersey Illinois, He's a 750 guy from day one. 309-995-3319.
Offline akranem
1977 cb750A carburetor valve solenoid (looking to buy)
« Reply #91 on: April 13, 2019, 09:54:43 PM »
hey everyone kind o new to the site almost a year now while i'm building my 1977 cb75A hondamatic.....anyways almost near completing my bike project when a few days ago my Valve Solenoid off the carburetor broke on me....near the top part where the hose meets the plastic tip snapped and its been impossible to ind one on ebay or any other site. honda part number 36161393033 anyways i anyone knows o a site where i can purchase one or even i you might have one or sale please let me know. thank you :-\
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
« Reply #92 on: April 14, 2019, 12:36:38 PM »
Are you interested in a functional equivalent - as in - something from a car that does the same function?
I was looking around, and found a few vacuum solenoids, some less than $20, that I believe would work.
https://www.ebay.com/itm/VACUUM-SOLENOID-SWITCH-VALVE-FOR-VSV-626-MILLENIA-ASPIRE-911-707-MAZDA-FORD/152332264392?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Dc500b13b48f2457a8f06d6e8287d01b5%26pid%3D100675%26rk%3D3%26rkt%3D15%26sd%3D382661100123%26itm%3D152332264392&_trksid=p2481888.c100675.m4236&_trkparms=pageci%3Ab1eaef01-5eeb-11e9-bb59-74dbd180e43a%7Cparentrq%3A1d53ed4316a0ab67342d0552fff94dbd%7Ciid%3A1
https://www.ebay.com/itm/EGR-Valve-Control-Switch-Vacuum-Solenoid-Standard-VS12T/362135958457?epid=2288059371&hash=item5450fc33b9:g:ny8AAOSwvoNblUHz
I wish I had one in my hands, and then I could tell you for certain . . . .
On our CB750A's one of the hoses connects the air cleaner - and is used to let air get into the dashpot - so it will go to its standby position (removes the idle speed increase).  The one with three connections should work, and the one with two should work, too (it has a hole built into its body).
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
  • dave the welder
« Reply #93 on: April 16, 2019, 08:38:07 AM »
Akranem have I got a deal for you .Another member (Lafindufondu)offered some  free parts which igot. all he wanted was shipping covered.the only stipulation was I was not to resell them but use them which I have on my chopper. so if you are not going to flip this bike but ride the snot out of it you can have the valve you need for shipping.if however you are planning to fix and sell bike right away you can have part  for 45 shipped. please pm me with your address and will get shipping cost. just paying it foreward to a fell matic owner
Offline bear
  • Leeton in Australia
« Reply #94 on: April 16, 2019, 06:35:17 PM »
Nice one Dave!
Offline akranem
« Reply #95 on: April 16, 2019, 06:47:41 PM »
@dave the welder i'm definitely not in this to flip or even sell my bike.....ive spent too much time building and learning as much as i could about cb750A hondamatics to ever want to get rid of it. if you can please email me at agamazium@gmail.com i'm willing to pay you for this part. thank you
  • dave the welder
« Reply #96 on: April 16, 2019, 07:33:16 PM »
fantastic glad to hear you are in it for the long run. I got your address and will try to get it mailed off to you in the next couple days. I will let you know the shipping cost and want nothing additional. if you ever have the chance to pay it forward go for it
Offline akranem
« Reply #97 on: April 16, 2019, 08:43:41 PM »
@raymond10078 you really think using one of these car Vacuum solenoid switches would work? i mean i get in a way it should because it serves the same purpose but has anyone ever done it before? i have managed to remove the air filter box and switched over to pods so the extra hose lead to the air box would automatically be eliminated meaning i would only need 2 ports to get it to work properly.....i ordered a cheap one off ebay and i'm willing to experiment to see what happens.
i anyone else has any other ideas or i anyone has switched over to car vacuum solenoid to replace the carburetor valve solenoid let me know please im desperate.
Offline akranem
« Reply #98 on: April 16, 2019, 08:49:43 PM »
@dave the welder thanks man....i really appreciate you helping me out.....im also going to try that other method as well just to see i maybe this might help anyone else along the way....but im thinking hondamatics being just a little different because of the crab setup might help others in the future in case anyone is willing to try it as well.
i will soon be posting pics o my whole bike build process to how where i am with my bike along with what kind o modifications can be done with hondamatics.....i strongly think they are rear and anyone who can get a hold of one do it and make it happen
  • dave the welder
« Reply #99 on: April 17, 2019, 03:19:43 PM »
Akranem put it in the mail today. let me know when u get it
