Author Topic: Cheap aftermarket Carb O-rings  (Read 1174 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
« on: November 12, 2013, 06:51:39 PM »
Are aftermarket Carb O-rings crap?   >:(
One month after replacing all the carburetor o-rings on my CB500 I found that all of them were brittle and the ones between the carbs were leaking.
Ive never seen o-ring go bad this fast.
I ordered OEM kit from Honda and replaced then all.
Has anyone have any experience with this, bought them on eBay.
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Re: Cheap aftermarket Carb O-rings
« Reply #1 on: November 13, 2013, 10:15:04 AM »
buy Honda brand only.
if you cant, Viton (FKM) has the best temp and chem resistance.
Offline Bailgang
  • Scott
  • Indiana
« Reply #2 on: November 13, 2013, 02:22:28 PM »
+1
Viton o-rings did the trick for my 550.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: November 13, 2013, 02:46:29 PM »
My first set of carbs i used honda kit, then after that I've been using those ones off eBay with no issues for my other bikes
CB550 K0
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #4 on: November 14, 2013, 10:52:33 AM »
+1 on Viton.
Offline rtbmrgl
« Reply #5 on: November 14, 2013, 11:29:39 AM »
Thanks for the reply's. I was pretty shocked they deteriorated so fast.
Does Viton sell o-ring kings for bikes or do you order size to fit. Does anyone have a list of the o-ring sizes for the CB500 carbs?
thanks, Mark
Roseville, Ca
Got Points!
« Reply #6 on: November 15, 2013, 01:11:32 PM »
buna-n & nitrile have OK chem resistance, but they wont last long with temps over 200F.  viton(aka FKM) is the material, not the mfr, and will withstand temps up to ~400F
there are metric viton o-ring kits available online. they aren't cheap.  it gets expensive when you have to take the time to do it all again down the road.  (I just replaced 6 orings, none larger than 18mmx3mm, for about $22)
all of the oring sizes are listed in the parts fiche pages for your bike.  check them out on cmsnl.com
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #7 on: November 15, 2013, 01:41:56 PM »
I buy the honda kits. No problemo.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline Xnavylfr
« Reply #8 on: November 15, 2013, 02:34:37 PM »
WOW, somebody saw you guys coming!! I just bought some VITON "O" rings for the 750  carb T fittings from NAPA and they cost me around  2$ each.
Xnavylfr(CHUCK)
Offline Bailgang
  • Scott
  • Indiana
« Reply #9 on: November 16, 2013, 06:03:03 PM »
Xnavylfr(CHUCK)
Not here in fact my local NAPA had the same o-ring assortment I had which was nitrile. I had to order mine online because nobody around here had viton.
Scott
71 cb350 twin
77 cb750 F2
« Reply #10 on: November 18, 2013, 07:12:06 AM »
Just take the rings with you to your local o-ring dealer if they have not disintigrated yet, they should be able to find you the proper fit.
