Author Topic: Rubber Seal Inside Air Box?  (Read 1593 times)
Offline Travis..
« on: November 13, 2013, 12:08:45 PM »
Can anyone identify or send a part number for the Rubber Seal that goes along the edge of your Air Box? Once you open the box up it remains attached to the top half; looks like it grabs the lip and ensures an Air tight fit between the two pieces.
I'm cleaning up an Air Box I just got and the rubber seal is incredibly worn, it's missing in one corner and the front bit won't stay attached and just hangs loose.
I'm searching on Google but can't find a replacement or even the name of this part. Anyone have some advice?
CB750K6
Offline wowbagger
  • Not much of an
Re: Rubber Seal Inside Air Box?
« Reply #1 on: November 13, 2013, 12:14:00 PM »
What year and model bike?
Offline Travis..
« Reply #2 on: November 13, 2013, 12:46:18 PM »
CB750 K6.
 I believe its number 10 in the Diagram below.. I'm at work and can't look but I could have sworn it was attached to the top where the number 2 is. Found this Part Number: 17219-300-010. It's only listed on Parts Sites as 'Rubber'. Is this what I'm searching for?
CB750K6
Offline Travis..
« Reply #3 on: November 13, 2013, 12:54:47 PM »
Never mind; I found it. 17221-341-000
CB750K6
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #4 on: November 14, 2013, 09:14:33 AM »
Also needed one, and figured I was SOL... thanks for starting this! I got mine from Partzilla.
http://www.partzilla.com/parts/detail/honda/HP-17221-341-000.html
I wonder how much my tuning will change after eliminating such large gaps in my air box?
« Last Edit: November 14, 2013, 09:16:23 AM by evanphi »
--Evan
1975 CB750K "Rhonda"
« Reply #5 on: November 14, 2013, 09:19:51 AM »
MIGHT be a little richer.  make those carb adjustments(if needed) before you add your exhaust can.
Offline evanphi
  • Apparently I'm an
« Reply #6 on: November 14, 2013, 10:09:49 AM »
Figured as much. I will try turning my screws out 1/4 turn. Everything else was at stock with the old baffled MAC muffler. When I recently changed my plugs, I noticed they looked a little on the lean side for my preferences.
--Evan
