Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
Moving along nicely, love the Yamiya gear...
Quote from: Retro Rocket on December 22, 2013, 05:58:01 PMMoving along nicely, love the Yamiya gear... Thanks for stopping by Retro.
Quote from: tweakin on December 23, 2013, 06:58:20 AMQuote from: Retro Rocket on December 22, 2013, 05:58:01 PMMoving along nicely, love the Yamiya gear... Thanks for stopping by Retro. Been lurking the whole time...
Quote from: Retro Rocket on December 23, 2013, 11:59:27 AMQuote from: tweakin on December 23, 2013, 06:58:20 AMQuote from: Retro Rocket on December 22, 2013, 05:58:01 PMMoving along nicely, love the Yamiya gear... Thanks for stopping by Retro. Been lurking the whole time... Good, I was starting to get hurt feelings... Happy Holidays brother.
I'm subscribed. This looks amazing so far, Tweakin. The gauges, I am impressed with how well you resurrected them.
Wow, that head looks better than new.
The black oxide...keep lightly oiled, as you know, they rust easy otherwise and are a pita to clean up. Wonder if silicone would protect them from rusting but keep the dirt buildup to a minimum?Who did your head work? Mike R?Was the head ported at all? I presume with the nice upgrades to top shelf merchandise you had some work done on the head to eek out more performance...David
Quote from: RAFster122S on December 31, 2013, 06:54:14 PMThe black oxide...keep lightly oiled, as you know, they rust easy otherwise and are a pita to clean up. Wonder if silicone would protect them from rusting but keep the dirt buildup to a minimum?Who did your head work? Mike R?Was the head ported at all? I presume with the nice upgrades to top shelf merchandise you had some work done on the head to eek out more performance...DavidBe very careful using silicone on the black oxide, most silicone is acidic and will promote rust, there are non acidic versions that would work, ever see all the dodgy leaky windscreens "fixed up" with silicone.? most just about fell out due to rust not long after...
Top notch Tweakin, are you going to use lock washers with the 12 points? Just my 2cents but you should hit the exposed ends of the bolts with a file/polisher for nice clean look
"Top Notch Tweakin", sounds like you have a new name?
