Author Topic: Quick question on tapered bearing install  (Read 585 times)
Offline izzyryder
« on: November 15, 2013, 07:38:22 AM »
I'm putting a set of all balls tapered bearings in. I noticed that one race is taller and one is shorter.
I just want to confirm that the taller race and bearing goes in the bottom correct?
Should be thin washer, seal, then taller bearing on bottom?
Re: Quick question on tapered bearing install
« Reply #1 on: November 15, 2013, 08:22:35 AM »
« Reply #2 on: November 15, 2013, 08:28:03 AM »
There is only one way to place those bearings - they have different inner diameter since the triple tree is stepped down.
Offline izzyryder
« Reply #3 on: November 15, 2013, 04:48:01 PM »
Yes you're right.. When I went to go install them only one would fit in the top and vice versa.
Thanks for the replies and the pictures.
