Author Topic: Opening an engine, what should I check/replace/look for?  (Read 2719 times)
Offline ncstatecamp
Re: Opening an engine, what should I check/replace/look for?
« Reply #25 on: November 20, 2013, 01:27:59 PM »
I was trying to think of which gaskets I'd heard anything about an Athena was the one I had heard bad things about. When I took off all the covers to polish them I ended up lazer cutting all my own but can't really do that for head or base...
What exactly is a port job? I always hear that and couldn't figure it out.
Offline setdog
« Reply #26 on: November 20, 2013, 01:46:23 PM »
"Some" white smoke on startup, I believed was considered normal.
Oil leak by the exhaust valve? Is it coming out the exhaust port? Into the exhaust pipes?
Or just leaking onto the fins?
Try to determine exactly and accurately where this oil leak is coming from, otherwise
You seem to be headed towards an unnecessary rebuild.
My toolbox consists mainly of hammers.
76 CB 200T. (sold)
75 CB 750 K5. (sold)
74 CB 750 K4. (current rider)
73 CB 750 K3. (build)
https://www.youtube.com/user/setdog100
Offline ncstatecamp
« Reply #27 on: November 20, 2013, 02:03:45 PM »
Set dog, originally I thought it was a head gasket leak but after watching a rebuild video and looking at a few threads I'm pretty sure it's the stud seals. From what I understand when one of those tears/brakes/leaks it can easily look like a head gasket leak since that vents to the air. Obviously something in the engine is leaking and I've got 90 psi when I had 120 so other stuff has worn down too. Most of this is, while I've got an engine with unknown wear I might as well do some recommended replacements so down the line, when I don't have access to my tools I won't need to.
« Reply #28 on: November 20, 2013, 02:11:19 PM »
cliff notes version - cylinder head 'porting' is the cleaning and reshaping of the intake and exhaust 'ports' to maximize flow, and power output.
Offline setdog
« Reply #29 on: November 20, 2013, 02:17:59 PM »
The reason for my reply is because I tore down an engine because a pistone wouldn't fire.
Turned out all I needed was to clean carbs better.
76 CB 200T. (sold)
Offline ncstatecamp
« Reply #30 on: November 20, 2013, 02:21:27 PM »
Alright thanks fly, I thought it might've been something like this. Is this a difficult task or just time consuming? Recommended?
Setdog- I had another thread a while back where the consensus was it was those stud covers. The lack of compression is newer but previously assumed.
« Reply #31 on: November 20, 2013, 02:40:03 PM »
not something you can adequately do at home.
contact member mrieck.  he IS the guy.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #32 on: November 22, 2013, 06:45:54 AM »
Ok one question that has been overlooked here by all. After the 5K run, did you check your timing and readjust your valves before the compression test?
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Offline ncstatecamp
« Reply #33 on: November 22, 2013, 11:23:16 AM »
At about the 3.5k mark I did a full 3k tune up. Timing, points gap, tappet adjustments, etc. so it's not all spot on but not totally out yet.
