Author Topic: No. 2 cylinder cold start  (Read 1752 times)
Offline clintcd
« on: November 17, 2013, 08:23:59 AM »
When starting my bike the No 2 cylinder is always slow to fire, I have serviced the engine and synchronized the carbs but no improvement, I suspect that I have a vacuum leak and if I do is the fault likely to be with the solenoid valve or the check-valve.  Can either of these parts be serviced, All the vacuum lines look fine. I would be grateful for any advice.
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: No. 2 cylinder cold start
« Reply #1 on: November 17, 2013, 01:13:15 PM »
What does "slow to fire" mean?
If you're thinking vacuum, I doubt that either of the two would be the cause of a vacuum leak. Maybe the diaphragm itself has a leak.  You can easily test the diaphragm but connecting another hose - sucking it down - and watching to see if the diaphragm holds or not.  You could also test the whole series of connections the same way too - but getting to the #2 carb connection can be tough.  Vacuum lines can "look" fine and still leak.
What work was done during the "servicing"?
Assuming that "serviced" means a complete 3,000 mile tune-up, what about the spark plug caps?  They are often overlooked.  They should measure roughly 5k ohms.  They are just twisted onto the cable, having a center core that is like a wood screw.  Also, others cut a 1/4" or so off of each cable to "get to" good (i.e., not oxidized) copper.  If you don't have a means to check the caps, you could easily swap #2 and #3 spark plug wires, and see if the problem moves to the #3 cylinder.  Another possibility is the spark plug wire itself - possibly shorting to the engine.  The swap test may reveal that, too.  Some have had luck running the bike in a completely dark area, and can see the arcs from the wire to the engine.
Lastly - what work, if any, was done to the carbs?  What is the history of the bike - and how do you know it is not a fuel-related problem?  Did the carbs adjust/respond as expected when you set the idle mixture?
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline salukispeed
« Reply #2 on: November 18, 2013, 11:11:59 AM »
+1 on the info so far. You might also check the plug its self. If the plug is fouled wet black it can fail to fire accross the gap  until it dries up with a little heat. You could swap it with another plug that you know is working properly Also a float setting too low can cause a lean condition that really shows up when cold.
1974 CB750 K4
1970 CT70
1966 CA77 (305 Dream)
1984 GL1200 Interstate
1977 750A
1972 CL100
Offline clintcd
« Reply #3 on: November 23, 2013, 07:32:39 AM »
Thank you both, got back to it this morning, the problem was with the plug cap. All sorted now.
