Author Topic: Painted stripes versus decals?  (Read 2679 times)
Offline Jayelwin
« on: November 17, 2013, 12:57:32 PM »
So my paint guy has my tank and my side covers. I've got all brand-new replica emblems on the way to make it an accurate reproduction and we think we've matched flakes sunrise orange nearly perfectly. He has proposed painting the stripes on instead of using the replica decals that I bought. Now obviously without thinking of accuracy everyone would agree that would be better. I'm thinking of foregoing the accuracy of the decals and allowing him to paint them on as this would generally lend itself to an overall better look. Obviously a purist or museum curator would probably find plenty of other flaws on my reproduction so I'm generally thinking that wouldn't be terrible. Any strong opinions out there?
Offline Johnie
Re: Painted stripes versus decals?
« Reply #1 on: November 17, 2013, 01:05:35 PM »
My KO & K1 are painted on. I have a very detail oriented painter. You have to be sure he takes pics and measures everything from the width to the curve before he strips it.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline Jayelwin
« Reply #2 on: November 17, 2013, 01:10:03 PM »
Wow, that looks nice in paint! OK you convinced me.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: November 17, 2013, 01:24:01 PM »
John's do look great. When I had all body work repainted on my K0 some years ago I did use decals which I provided to the painter. That was pretty much the extent of my input to the effort. As it turns out the decals were not quite perfect dimensionally. He did a great job trimming them, proceeded to apply them over the paint and under many coats of clear coat. They "look" painted, you really can't tell they are not painted on. Just another option.
« Last Edit: November 17, 2013, 02:30:57 PM by Bob Wessner »
Offline Sgt.Pinback
« Reply #4 on: November 17, 2013, 01:51:01 PM »
Where KO tank stripes originaly painted?
Doc, I love a motorcycle!
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: November 17, 2013, 02:32:49 PM »
Not that I know. Perhaps someone knows better. My goal was a "presentable " reproduction.
Offline Mini Mo
« Reply #6 on: November 18, 2013, 08:45:02 AM »
Not sure if this pertains to the KO but I just stripped the Garnet Brown tank on my K1 and the stripes were painted on.
750 K1 (Just finished)
750 K4 (In Process of resto)
2) 750 K6's (Restored and sold)
750 K5 (Restored and sold)
'75 850 Norton Commando (Restored and sold)
'99 Triumph Tiger (Daily rider)
Offline KayOne
« Reply #7 on: November 18, 2013, 08:57:40 AM »
Mini Mo, where the painted stripes metallic gold? The farther I progress on my K1, the less I want to make it "exact". I am thinking of using a brighter metallic green and a rich gold metallic painted stripe on my Valley Green Metallic bike.
CB750 K1 restored
1979 CB750Fz - original except for exhaust, 14000km
1984 VF45F Interceptor - all original, 12000 km
1968 S90 - all original, 2100 miles
1973 H2a, Restored
1973 H1D, next project
CB750K1 (sold)
1976 KZ900 (sold)
1981 CB900F (under restoration)
2015 Yamaha FJ09, my appliance rider
fendersrule
« Reply #8 on: November 18, 2013, 09:12:43 AM »
Another vote for decals under clear coat.
Offline Jayelwin
« Reply #9 on: November 18, 2013, 11:23:47 AM »
Decals are $60. He wants $250 to paint stripes.
Offline lone*X
« Reply #10 on: November 18, 2013, 11:44:47 AM »
There would be additional labor for the painter to apply the decals prior to clear coating the tank over your $60 cost, but I doubt it would be as high as $250.   I would go with the decals as it is absolutely more original and probably save you half that $250.  If the tank is stripped already and no one recorded to placement exactly you are going to have to research the proper placement.  If its already stripped do the research yourself, don't trust someone else to get it right.
Lone*X  ( Don )
75 CB550K1
VTX1800C for two up cruisin.
Offline Jayelwin
« Reply #11 on: November 18, 2013, 01:14:04 PM »
He really wants to paint. I've seen his work and he's pretty talented. It might be more but I think overall despite accuracy it'll be better.
Offline Johnie
« Reply #12 on: November 18, 2013, 01:24:53 PM »
You hit it on the head Jay...might cost a bit more, but it really does look awesome compared to decals. I figure it as a one time paint so put a little more into the quality.
« Last Edit: November 18, 2013, 01:26:24 PM by Johnie »
Oshkosh, WI  USA
Offline Sgt.Pinback
« Reply #13 on: November 18, 2013, 01:37:46 PM »
I want to have as original as possible.
Any info to 1970 KO ?
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #14 on: November 18, 2013, 01:50:11 PM »
Whether a reasonable amount or not, the difference is significant in terms labor which is why I believe Honda did decals. Imagine painting vs. decals on the number of units they produced and the impact it would have on their bottom line and profit margin.
Offline Johnie
« Reply #15 on: November 18, 2013, 02:18:38 PM »
That is a good point Bob. Peel and stick was the Honda way back then. Fast was good. I do not think they even had the good tape for stripping back in those days.
Oshkosh, WI  USA
Offline calj737
  • I refuse...
« Reply #16 on: November 18, 2013, 03:40:36 PM »
Jay - another consideration for you: if you go with decals under clear, should you ever need to repair the paint/metal of the tank, forget it either taped decals. Paint can be more easily repaired.
For me, paint in your situation is a better solution and will yield a higher-end look. Tape can be really well done also, but there will be an edge of the paint thickness unless you really overcoat the color with more clear coats. Those added coats interfere with the best color of the paint being revealed (shine/depth/reflectivity).
These are more technical "issues" about paint vs tape, but you are spending a great deal of time and money now. Amortize the cost over 10-20 years of ownership on a beautiful bike. You'll never regret the added expense compared to the beauty. And I'll bet you dollars to donuts, the painted job will turn heads more... Simply because the paint WILL be a better result by virtue of fewer coats of clear.
My opinion, your bike, your wallet. Either way, love to see some pics as you close in on it.
Offline CB750R
  • 77 CB750F
« Reply #17 on: November 18, 2013, 03:54:25 PM »
I just had my tank painted had a paint mask made in vinyl so the painter used the decal as a mask the. Removed it.  Honestly I'm pretty happy with the results.
untitled-9830.jpg by CB750r, on Flickr
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #18 on: November 18, 2013, 04:03:54 PM »
I'd be happy too, it looks amazing. Cool technique too.
I have a motorcycle problem.
Offline calj737
  • I refuse...
« Reply #19 on: November 18, 2013, 04:42:25 PM »
If you're not happy, send it to me. I'll buy a whole new bike to put that lovely tank on! Very nicely done-
« Reply #20 on: November 18, 2013, 08:00:55 PM »
If done right, painted is the way to go.
