Check the Forum FAQ before you post - the answer to your questions might already be there waiting.
This is not a pod threadThis is not a #$%* on my vacuum gauges threadThis is a help or GTFO thread.
Remove the cover and it should come out with the key in it.
the number for the key should be stamped on the top of the barrel. You'll need to buy one if you want to get the lock out without destroying it
