Author Topic: Oh look another carb question...help....  (Read 1427 times)
Offline Mafia
« on: November 17, 2013, 09:36:18 PM »
My resto project has tossed me another question for the masses. My 77 750 f2 carbs seem to be different then the carbs both in the Manuel and the typical carb videos on the interweb.
I've soaked these puppies in 50/50 pine sol and warm water but it seems the slides are gooed into place. Carbs cleaned up nice,  but thought these slides were able to move just by being pushed up. Havent found a lot of info on these carbs.most have the four diaprams. These have a singal diapram pump. ( accel pump) any help is appreciated.
« Last Edit: November 17, 2013, 09:38:07 PM by Mafia »
Of all the things I've lost, I miss my mind the most
Offline SOHC Digger
  • I'm not an
Re: Oh look another carb question...help....
« Reply #1 on: November 18, 2013, 05:14:58 AM »
Not sure exactly what you asking here.  The stock carbs for the 77 CB750F are PD41B.  Yes, they have a single accelerator pump that feeds all four carbs.
Offline Mafia
« Reply #2 on: November 18, 2013, 05:31:04 AM »
Well, typed this late last night.anyway question is any idea how I can get these unstuck ? And mabey find some liturature on these carbs.
Offline SOHC Digger
  • I'm not an
« Reply #3 on: November 18, 2013, 10:57:45 AM »
If they are stuck, I would recommend tearing them down and rebuilding them.  Soaking the carb bodies in hot water and Simple Green or vinegar usually frees them up, but don't soak them for too long of you can discolor the aluminum.
Offline Mafia
« Reply #4 on: November 18, 2013, 11:15:18 AM »
Good advice thank you. Thought the pinsol bath might free them up but to no avail. Is there any pieces inside the slide tube that would be affected by carb cleaner?  Carbs look fantastic other then the stuck slides.
« Reply #5 on: November 18, 2013, 11:27:53 AM »
Use a heat gun on the carb bodies where the slides fit.  Work the slides and use something like WD40 to lube them while hot and work them free.
I don't know why you thought pine sol was a good idea.  I suppose it is cheap.  Pretty sure it will eat metal, even if slowly.  Carb cleaners are available that won't eat metal.
Soak and pray are not effective cleaning methods and a poor gamble for success, imo.
If you insist on a soak to free slides, use something with penetrant action, like acetone.  Beware of plastic, rubber and fibrous seals that dissolve in acetone.
The Honda shop manual supplements have some info on the PD style carbs.
However, there have been many many thread topics with better detail in this forum.
Offline Mafia
« Reply #6 on: November 18, 2013, 12:06:35 PM »
Actually pinesol worked great. Only left it in a couple hours and came out looking fantastic.read about 100 testimonys regarding pinesol before i tried. Thank you for the great tip on freeing the slides it is exactly what I'm gonna try.
« Reply #7 on: November 18, 2013, 01:24:32 PM »
yes, but looks don't make your bike run...slides that are not stuck make your bike run
Offline Mafia
« Reply #8 on: November 18, 2013, 01:29:33 PM »
Very insightful.lol. bike sat for 22 years. I'm cleaning everything.
