Author Topic: pics of marks to setting valves  (Read 1716 times)
Offline mario medeiros
« on: November 18, 2013, 04:57:13 AM »
Need to set valves on my 75 cb550f not sure on where to line up the marks?and once i do the one side i just turn the motor over a full rotation back to the 1/4 and set the other valves?i see some use the t mark and others use the mark just to the right of the t,not sure which to line up.Thanks
Offline MoMo
  • Ride like you're invisible
Re: pics of marks to setting valves
« Reply #1 on: November 18, 2013, 05:12:47 AM »
The T indicates top dead center, which is where the valves should be set...Larry
« Reply #2 on: November 18, 2013, 07:01:29 AM »
Sorry but have anyone got a pic on where the marks are to line up?manual of mine does not show well.Also is it as easy as rotating the motor to the marks then setting the valves needed then you rotate a full turn back to the t mark 1/4 then set the rest?And one last one is what is the 2/3 marks for?Thanks
« Reply #3 on: November 18, 2013, 08:13:03 AM »
through the timing plates hole, you should see marks  for T and F  one mark looks like   l    and the other marks look like   l l
you'll need to get the  l  mark for T lined up with the indicator  \l/  , seen just above it looking through the timing plate hole.
check #1 intake and exhaust for looseness.  if there is no play, rotate the cam 365 with  'the big nut' back to the  l  mark for T
and check #1 intake and exhaust for looseness
this is a useful thread...http://forums.sohc4.net/index.php?topic=112542.0
« Reply #4 on: November 18, 2013, 09:02:21 AM »
Thats great thanks
Offline lucky
« Reply #5 on: November 18, 2013, 06:34:42 PM »
The "T" mark needs to be lined up, but  BOTH cam lobes on that cylinder you are adjusting should have both cam lobes facing down and out at 45º.
That is the compression stroke.
Offline Bodi
« Reply #6 on: November 18, 2013, 08:36:07 PM »
If you have the electric starter installed, turning the motor over backwards is difficult. Remove the spark plugs so the engine turns fairly easily.
Don't turn over the engine using the large "nut" on the points shaft: this is a fragile piece - it's easy to break it this way. Remove the alternator cover and turn the engine using the head of the centre bolt. If that comes loose, you can just grab the alternator rotor and turn it.
The marks are visible through a hole in the points plate, T 1-4 and T 2-3 (TDC for 1&4, TDC for 2&3). It is not critical to be exactly at TDC, just close is OK for valve adjustment "my way".
I do the valve adjustment in four steps. You can do it in two but that is confusing to me, I like to do one cylinder at a time rather than jumping all around.
Turn the engine to T 1-4. 1 and 4 will both be at TDC - one of them will be between compression and power stroke and the other between exhaust and intake strokes... but which is which?
My easiest way to find compression stroke is to watch/feel the intake valve tappet: it closes (the tappet end of the rocker rises) as the piston reaches BDC before going up on the compression stroke.
I get #1 at TDC after compression stroke. Both #1 valves will be fully closed, and I adjust both tappet clearances.
The firing order is 1-2-4-3 so next I rotate the crank half a turn to T 2-3: that will have #2 at TDC after compression and ready for tappet adjustment.
Another half turn to T 1-4 will have #4 ready to adjust.
One more half turn to T 2-3 and adjust #3.
Done! I just go around again and check them to be sure: feeler gauge with nice drag and the nut tight.
If any tappet clearance is super tight after loosening it a turn or two, you are probably on the wrong stroke and the valve is actually slightly open.
