Author Topic: Nitrous  (Read 1857 times)
Offline afkrejci90
Nitrous
« on: November 21, 2013, 03:13:29 pm »
So I'm wondering what is needed besides what I already have to use a NO2 setup for trips to the track.  Forged pistons and Carrillo rods I already have, along with an APE lightened crank, is there anything more that I would need to strengthen the bottom end?  Will the CB750 even hold up with NO2?
'78 CB750K http://forums.sohc4.net/index.php?topic=105327.0
'80 CB750C - Sold
'06 CBR600RR
  • Moderator
Re: Nitrous
« Reply #1 on: November 21, 2013, 04:09:36 pm »
I don't see why not when you consider what has been pumped into them in the past.
It's not going to last as long as a motor on just gas but who knows how long?
It's normally the top end that takes the bunt of it from what I've heard.
Start with low % ages.
Sam. ;)
Offline afkrejci90
Re: Nitrous
« Reply #2 on: November 21, 2013, 04:23:32 pm »
It's mainly going to be street with the occasional trip to the track each year, so the amount of abuse will be kept a minimum.
'80 CB750C - Sold
'06 CBR600RR
Re: Nitrous
« Reply #3 on: November 21, 2013, 04:54:57 pm »
What size pistons?
How about top and bottom end studs.
Offline BLUE71TURBO
Re: Nitrous
« Reply #4 on: November 21, 2013, 08:10:29 pm »
 Don't forget real good valve springs and heavy duty case and cylinder studs. Also you will need to run a copper cylinder head gasket along with having your cylinders " O " ringed with copper wire. Nitrous Oxide can be real fun but any disruption in the delivery of the fuel " gas " side of the system will create a melt down bomb between yer legs.   :o  Special filters are needed for both sides of the system so that the solenoids super small orifice's don't get plugged.   ;)
Offline afkrejci90
Re: Nitrous
« Reply #5 on: November 21, 2013, 10:54:49 pm »
72mm pistons with the APE studs.  The head will have the works, springs, valves, etc.  Do you have anymore info about the copper wire "o-ring" I've never heard of this before.
'80 CB750C - Sold
'06 CBR600RR
Offline dragracer
  • CB750F Dragbike
Re: Nitrous
« Reply #6 on: November 22, 2013, 12:16:33 am »
Basically a shallow grove is cut around the circumferance of the top of the liner in the cylinder. A thin wire, steel or copper is inserted in this grove. When the head gasket(copper) is torqued down, it bites into the o-ring to form a tight seal around each cylinder to keep compression from leaking past under extreme cylinder loading from boost or nitrous. I think many have success with the MLS gaskets these days versus o-ringing or copper head gaskets. Personally. i'll stick with the tried and true o-ring methods. When i see  the car guys all go to MLS, i might change my mind.
Offline afkrejci90
Re: Nitrous
« Reply #7 on: November 22, 2013, 03:31:58 pm »
I wonder if anyone around chicago can do that, seeing there's basically no one around here that has no machinery to work on these small engines, but maybe APE?
'80 CB750C - Sold
'06 CBR600RR
Offline joe p
Re: Nitrous
« Reply #8 on: November 22, 2013, 03:35:05 pm »
Fast by Gust did all my work.
Re: Nitrous
« Reply #9 on: November 22, 2013, 03:43:47 pm »
72mm pistons....how large a shot are you going to use? 20 jets on the nitrous side? It will be tough on the primary chains. Are you going to use a progressive feed box?
Offline afkrejci90
Re: Nitrous
« Reply #10 on: November 22, 2013, 06:45:57 pm »
I'm going to keep it down to a small shot to begin with.  There's already going to be a big performance increase just from the big bore and other mods.  This is just to push that envelope a little further  ;D  I guess it wouldn't hurt to run a feed box.
« Last Edit: November 22, 2013, 06:48:37 pm by afkrejci90 »
'80 CB750C - Sold
'06 CBR600RR
Offline dragracer
  • CB750F Dragbike
Re: Nitrous
« Reply #11 on: November 22, 2013, 06:48:26 pm »
Ouch, using 20 on the nitrous side with the traditional 4 spread makes it 24 on the fuel side. Damn, thats over a 50 horse shot.
Re: Nitrous
« Reply #12 on: November 23, 2013, 07:25:09 am »
That's what I used on my FJ Frank....no progressive box. I broke some clutch parts.
