Author Topic: Blackfin CB750 F1 BLASTER  (Read 28706 times)
Offline Blackfin5
Re: Blackfin CB750 F1 BLASTER
« Reply #50 on: April 01, 2014, 06:39:53 AM »
Asking Chris to swap is a good idea.  If not, perhaps grind off the weld carefully, polish up the can and new mount in line with passenger peg.  A through bolt would be so clean.
Offline Blackfin5
« Reply #51 on: April 30, 2014, 12:05:02 PM »
In the month since last posted I've been in Cape Town for a mate's wedding.  The day I returned Jazzy was run over in my own driveway, 10 feet from the house.  She fractured both hips, had surgery, and is recovering.  She may be paralyzed in one rear leg but time will tell.  So the projects have suffered a little bit.
I received the black Sun rims laced up and trued by Buchanans, with new BT-45Vs.  110/90-18 front and 130/80-18 rear.  The only thing holding up the install is the rear hub o-ring (68mm x 2.6mm).  When that last part arrives, I can take off the polished Excel wheels and install those on the 550 build.  I think I like the polished rims better.
Also, I wired up the twin LED tail light which doubles as turn signals.
We've also put some work into my buddy's 550 build.  You can see the polished aluminum engine parts and the black powder coated hubs, rims, and fork sliders.  All new steering head, wheel and swing arm bearings/bushings.  His seat, tank, fender and side covers are out for painting by the same guy that painted my parts.  Without being a spoiler, his colors are root beer and grey, with red accents.
Cheers!
« Last Edit: April 30, 2014, 12:08:41 PM by Blackfin5 »
Offline dagersh
    • Photos
« Reply #52 on: April 30, 2014, 12:18:41 PM »
Oh Man,
I hope Jazzy Recovers fast and well.  My wife and Adopted a Rottie who was born without a hip socket.  After all her surgery she is walking and doing great.  They can work miracles with dogs these days.
Keeping my fingers crossed!
Gersh
1962 CA95
1966 Black Bomber
1966 CA77 Dream
1967 Superhawk
1970 CB750K0
1972 CL350
1972 CB450/500 Custom
1972 CB500K1
1975 CB550F
1976 CB400F
1975 CB750 Future Restoration
1976 CB750K6
1976 CB750F
1976 GL1000
1968 Suzuki T500 Cobra
1990 BMW K1
2001 'Busa
2003 RC 51
Bunch of Guzzi's
Offline Blackfin5
« Reply #53 on: April 30, 2014, 12:22:51 PM »
Thanks, Gersh.  I appreciate that.  She is a special girl.
« Reply #54 on: April 30, 2014, 01:28:41 PM »
Best wishes to Jazzy for a full recovery.  That's a heartbreaker.
Offline Blackfin5
« Reply #55 on: May 01, 2014, 07:23:27 PM »
On the exhaust hanger, I got in touch with Chris and he is sending me a new alloy sleeve for the can without a mount.  I can then remove the mount on my can, put on the new sleeve and weld on the mount so it lines up with the mount for the passenger peg.  Bolt together and done. I think this will be a good solution.
Offline tweakin
  • tear down
« Reply #56 on: May 01, 2014, 07:44:37 PM »
Speedy recovery to Jazzy brother...  The bike can wait.
Offline Blackfin5
« Reply #57 on: May 01, 2014, 09:23:56 PM »
Amen.  Thanks.  She's home now.  Long recovery.
Offline Blackfin5
« Reply #58 on: May 02, 2014, 08:34:11 PM »
Jazzy is home.  Stitches are out.  Lots of therapy ahead - can't walk yet, just hobbles on 3 legs and is still in pain from the surgery.  She has a motorized wheelchair.
With Jazz keeping me company, I finished building the front & rear wheels.  Thanks to Godfrey for the lightened and drilled rotors.  Cheers.
« Last Edit: May 02, 2014, 08:35:59 PM by Blackfin5 »
« Reply #59 on: May 02, 2014, 09:30:16 PM »
Wheels look nice.  Go Jazzy.  Hope her rehab goes well.
Offline Blackfin5
« Reply #60 on: May 02, 2014, 09:43:43 PM »
Damn!  I forgot to put in the o-ring (parts fiche #21) under the speedo gear box retainer.  Is it crucial, or may I do without it?
Offline Blackfin5
« Reply #61 on: May 03, 2014, 11:18:51 AM »
...edit...turns out I had a NOS o-ring so unbolted the hub and on it went.  Eazy peazy.  I was worried I would have to wait for the UPS man to get these wheels on.
Offline Blackfin5
« Reply #62 on: May 03, 2014, 09:51:53 PM »
Need help......calling Tweakin, brandEn and other "F"ers.
After installing the rear wheel, there is a 1/2" gap between the rear caliper and the swingarm.  That's 1/2" of the rear axle showing in the gap.
Below is the parts fiche for a 1976 CB750F.  The collars/spacers no. 12, 13 & 15 are all in place.  It's the same hub I removed from the bike and kept all axle and hub parts in the same box.  The only things I did was polish the hub and sprocket carrier, install 3 new SKF bearings, powder coat and rebuild the caliper, reinstall the bearing retainers, and put on a new sproket.  The internals are all same parts which came off this bike.  There are no left over parts; and the parts fiche shows no other spacers/bearings.  I did not over insert the bearings - pressed in only to the edge of the axle collar - and the wheel spins very freely with the new bearings.
This is the left or sproket side of the hub.  Collar no. 13 is in place (althout difficult to see due to the angle of the photo) and allows the wheel to spin freely.
The nut on the axle in the photos is in the exact location when I started the disassembly.
Where did I go wrong???  Please help.  I cannot figure this out.
In any event, the front wheel went on perfectly.  Was only a tad tight going on in between the fork sliders due to the 110 tire, but once in place spins perfect and true.
Offline brandEn
« Reply #63 on: May 03, 2014, 10:28:01 PM »
Looks like the spacer on the sprocket side is missing? That Cush drive should not rest on the chain adjuster.
Offline brandEn
« Reply #64 on: May 03, 2014, 10:29:39 PM »
I see you mentioned it's installed but it may need to be flipped around.
Offline brandEn
« Reply #65 on: May 03, 2014, 10:31:51 PM »
And where is spacer #15?
Offline Blackfin5
« Reply #66 on: May 04, 2014, 04:17:27 AM »
brandEn.  Thanks for checking this out.  I think I may have installed #15 from inside the bearing with the smaller diameter protuding through to the outside - barely.  I will have to walk down to the shop to see.  I have done it that way on a different build, correctly, but may have done that here incorrectly.  If so, that's what I get for rushing.  Will report back shortly.  Again - thank you.
« Last Edit: May 04, 2014, 04:54:52 AM by Blackfin5 »
Offline Blackfin5
« Reply #67 on: May 04, 2014, 04:23:59 AM »
Looking at the parts fisch it shows the #15 shouldered spacer "inside" of the sproket carrier bearing but it seems to make sense if used as brandEn suggests, from the outside-in so the shoulder is the spacer bewteen the sproket carrier and chain adjuster.  Is the parts schematic wrong?  It also seems you need #15 between the hub and cush drive to prevent the cush drive from seating too deeply.  Head scratching here.
« Last Edit: May 04, 2014, 04:55:51 AM by Blackfin5 »
Offline Hon3ybadger
  • Someday it will run...
« Reply #68 on: May 04, 2014, 06:23:32 AM »
I don't see 12, 13 or 29 on your bike.
Offline Blackfin5
« Reply #69 on: May 09, 2014, 01:22:39 PM »
Discovered the problem after removing the rear wheel.  The no.13 spacer (sproket side) I used wasn't the true 13 from when I disassembled the axle/hub.  It was same I.D. and slid over axle fine but about 1/2 the length of the true no. 13 - so it got sucked all  the way in the retainer/dust seal. Not sure where it came from.  I found the true no. 13 in my buddies 550 parts box.  Maybe he got one of his spacers mixed up with mine.  Now the whole assembly is 1/4" too wide to fit within swingarm.  Geez.
Offline brandEn
« Reply #70 on: May 09, 2014, 01:42:04 PM »
You know what I did something similar on my first go around and I discovered it was the spacer for the oil filter....
Offline Blackfin5
« Reply #71 on: May 09, 2014, 04:17:37 PM »
Bonehead on my part. You can see the no. 13 imposter in reply #62 above barely protruding from the sproket side retainer.
Offline Blackfin5
« Reply #72 on: May 27, 2014, 08:14:38 PM »
Well, with the correct spacers and axle collars, the rear axle/brake caliper fits precisely within the swingarm.  Torqued to 70 ft-lbs and I coundn't be more pleased despite my bonehead assembly.
I installed the new D.I.D. 0-ring chain using the D.I.D. specified tool; however, I'm not all that confident about the "A" position rivet although I followed directions very carefully - and I've used it before with no issues.  But I am prone to making stupid mistakes (especially after a few brewskies).
This phase of the build is very close to completion.  I have new S.S. oil lines.  I cleaned the oil tank today and could not believe the black muck inside.  It took several kerosene baths, a lot of shaking, an acetone rinse, then compressed air to get rid of the crude which built up in there over the past 38 years.  This is the before photo.  I gave it a new coat of black enamel gloss and is drying at the moment.
The only things holding me back are adding oil after the tank is installed, charging up the battery, and my seat pad to be returned from the upholstery place.  They had to wait on their order for some smooth light grey leather.
« Last Edit: May 27, 2014, 08:16:18 PM by Blackfin5 »
Offline Blackfin5
« Reply #73 on: May 28, 2014, 07:48:35 PM »
I really struggled with the stainless steel oil lines.  I was going to install the new headlight and bucket, but on this hot afternoon, I ran out of steam.
Offline CB750R
  • 77 CB750F
« Reply #74 on: May 29, 2014, 12:43:42 PM »
Lookin great, where did you get the oil lines from?
