There is a plate separator in the collector. All stainless construction.
Reverse cone and mounted to a natural mounting point (passenge peg mount hole) on the 750 with no hanger needed.
The angle of the rear pipe and cone match the natural angle of the frame and swingarm.
Easy access to oil filter. The horizontal bar is just part of the jig.
So far, I love how they look and fit; but until the Blaster is fired up, I have no idea how they will sound.
I very, very much like the motogpwerks 4-2-1 pipes for the 750; however, there are a couple minor issues: (1) the mount location on the can, as discussed in this thread, it requires a custom hangar or bracket to be fabricated regardless of a K or F. (2) the pipes do not exactly hug the underside of the frame and are directly under the oil drain plug. It's impossible to change oil without leaking onto the pipes. (3) the spigots going into the head are a bit undersized so it's difficult (for me at least) to get the copper gaskets to seal correctly.
This is not a sales plug and I am not involved with the manufacturing of these pipes except to offer up the Blaster as the template for the prototype. I understand that the plan is for these pipes to be put into production very soon to bolt up on both K and F frames. I am not yet at liberty to disclose the identity of these pipes, but will let you guys know as soon as I am able.
