Author Topic: Bartel CR750 oil tank  (Read 843 times)
Offline spiritof67
« on: November 24, 2013, 11:46:03 am »
The Bartel CR750 oil tank has three 90 degree pipes at the top - are all three vent tubes? Are the two parallel ones for some kind of separator and the third one just a vent? And why three? I'm sure there's a simple explanation that I'm just not getting...
Spirit
Offline napoleonb
Re: Bartel CR750 oil tank
« Reply #1 on: November 24, 2013, 02:32:57 pm »
The parallel pipes (one should be larger in diameter) go to the breather box under the seat, one is for supply (venting) the other lets condensed oil return.
The other one is a breather supply from the engine.
Offline spiritof67
« Reply #2 on: November 27, 2013, 01:04:35 pm »
Why does the oil system need a condenser? Most race systems I have seen just run a vent to either a container or a filter. Is there a need for the "breather box"? If so, what is the commonly used container, other than a $400 replica of a 43 year old canister?
Offline spiritof67
« Reply #3 on: November 27, 2013, 01:34:08 pm »
..or could you "repurpose" an evaporation canister say from an RC51 to do this job? Or just a container with one line in/one line out? Or just lead all three lines into an overflow tank?
