Author Topic: Cold Weather adjustments?  (Read 926 times)
Offline nccb
  • 1974 CB750 Four
« on: November 24, 2013, 01:33:38 PM »
When it gets cold, is it appropriate to adjust anything on the bike, i.e. air mixture screws or idle adjust?  I started mine up today (couldn't take it for a ride) and its about 34.  It started fine but began on 2 or 3 cylinders then kicked into all four.  I am assuming its just from the cold but want to double check.  Another reason was it had wispy white smoke coming from the exhaust, but I do spray WD-40 in the exhaust if I know I won't ride it in a week.  I think that was the reason it was smoking but am just looking for input on what others may do when it gets cold out.  Thanks for any input.?
Re: Cold Weather adjustments?
« Reply #1 on: November 24, 2013, 01:38:24 PM »
Put lighter oil in.if riding near or under zero, may not hurt to let it run post ride.. It may never really get to proper temp , and can get a lot of moisture in the oil.
 In the last 5 years up here i rode three winters,missing no more than 3  weeks out of the winter..
« Reply #2 on: November 24, 2013, 01:58:45 PM »
Perhaps your voltage was low. Be sure you top off your battery and use a Battery Tender. They don't run well on low voltage and our batteries do not have much capacity. The charging system doesn't do anything until ~ 1800rpm. While smoke could have been from the WD40, oil that accumulated and leaked down through the valves seals it probably was just condensation that is warming up.
Black 750K8
« Reply #3 on: November 24, 2013, 03:34:47 PM »
I'm about 30 miles south and don't make any changes. I might drop to 10-40 but not usually bike stays in the shop (heated during the day) about 65deg. so the oil does not get as cold I might let it idle 20 or 30 seconds longer no big deal around here over in the mountains is different.
« Reply #4 on: November 25, 2013, 04:49:07 AM »
I use Mobil Delvac 15W-40  in winter and try to reach 20 psi on the oil pressure gauge (I take 20  psi as fully warmed engine).
Offline flatlander
« Reply #5 on: November 25, 2013, 06:41:36 AM »
most winter it's around freezing here, for some time it can be somewhat lower. i don't do anything specific with the bikes.
if i did not run them regularly (say, less then once a week) i'd probably plug the batteries in a charger. i keep using 10w-40 oil year-round.
when it's really cracking cold your air/fuel mixture will get a bit leaner. for those few times it happens here, i don't adjust anything, thought. it depends on where you live and the conditions there, i guess.
white smoke from the exhaust in these conditions is usually condensation and should go away after it's properly warmed up.
Black 750K8
« Reply #6 on: November 25, 2013, 06:50:12 AM »
If it is going to sit for a while take the battery in to the house. Makes a good center piece for the dining table.
Offline lucky
« Reply #7 on: November 25, 2013, 06:20:23 PM »
No ,except to leave the choke on longer until it gets warmed up.
