Logo merchandise is available at the SOHC/4 Shop
I have one on my boat for pumping out my 20 gallon fresh water tank every fall. Works like a charm.
Quote from: Duanob on November 26, 2013, 11:22:26 amI have one on my boat for pumping out my 20 gallon fresh water tank every fall. Works like a charm.How are you powering it? Battery or the boat's power outlet? I've had no luck getting it to run off a charger because of the 4A requirement.....
Has any of you used this 12v utility pump from HF? More specifically, how do power it if you don't have a 12v car battery? Will a standard laptop 50w charger or a 12v DC 4.16A power supply make this thing run?
