Author Topic: oil under stator cover  (Read 955 times)
Offline pablo78cb550
  • mmmph.
« on: November 24, 2013, 09:46:36 PM »
does the 78 CB550K have a dry stator or what?
its not a lot of oil mind you, but i didn't think any should be under the cover.
now, i have the crank seals ready, but could it be the block plug o-ring seeping oil?
I'd rather not split the cases if possible.
Bikes in hand:
1977 Yamaha XS650
1978 Yamaha SR500 #119!
1978 Yamaha XS400
1978 Honda CB550K
1965 Ducati Monza 250
Sold off:
1992 Yamaha FZR600
1981 Yamaha Seca 550
Offline Dimitri13
  • 1974 CB550K
Re: oil under stator cover
« Reply #1 on: November 24, 2013, 11:04:48 PM »
There's an aluminum plug at the bottom. It's an oil passage under the crank. On the opposite side, there's a cap that you can undo. Stick something long in there and tap out the plug. There's o-rings on both of those.
There are also two oil drain caps underneath the engine, but unless they're leaking, no need to mess with em. Mine were on for so long I rounded one off and gave up.
« Reply #2 on: November 24, 2013, 11:49:19 PM »
its a dry stator,that little bung can be pulled out without knocking it through,replace its o ring first,clean the area and hope its fixed?
