Author Topic: CB500/4 First riding impressions  (Read 2337 times)
Offline Clasico
  • CB500 Four K1
« on: November 25, 2013, 10:55:25 AM »
Here are my first riding impressions after some 100 miles with my new bike.
Since everything depends on what you compare with, i'll use my, now gone, BMW R65 monolever as a benchmark.
For starters the new baby likes to be rev, otherwise it lacks punch. But what a glorious buzz she does. I'm acostumed to shift on low revs on the boxer and some other harleys i had, so first miles i was changing up at around 4k and wasnt getting much in terms of speed momentum. I reckon now that i should be shifting at 5/6k at least.
Gets very busy above 60 mph, again probably im acustomed to slow machinery.
However even being such a punchy bike does very well on slow riding in 4th and 5th.
Riding position is great, confy and old school. Is taller than it looks though, a bit challenging to move with my shorties. Its clearly not designed for sustained high speeds, good for training your neck and arms in return!
Cluth pretty stiff, dont know yet if anormally so.
Brakes similar to the boxer, close to marginal. However i may change my opinion once the front brake is adjusted, same for he clutch. Gears are a bit notchy but may soften with fresh oil and clutch adjusment
It goes very well on the twisties, maybe a bit front heavy.
Starting with the pedal is a fantastic experience, so cool and easy.
Overall, i still have to service the bike properly and learn how to drive a four, but she is a hoot to drive. And the smile factor is great.
Carpe Diem
Re: CB500/4 First riding impressions
« Reply #1 on: November 25, 2013, 11:23:37 AM »
I would suggest doing most of your riding in the 5-6k rpm range, and shifting much closer to redline.
@ 5-6k rpm, you're just getting into the meat of it  ;)
« Reply #2 on: November 25, 2013, 11:52:01 AM »
Engine red line is 9000 ish.  Anything below that is useable on a routine basis.  Quiet pipes allow you to wind it up with less guilt and less attention drawn.
They make HP and torque only when revved.  You will learn to use the transmission shifter almost as much as the throttle twist.
It will do high speeds easier than the rider.  Fairings make high speeds routinely easy for the rider yielding far less fatigue.
Open cockpit airplanes routinely have windshields.  Anything without a windscreen is a low speed vehicle, imo, with on-the-track exceptions.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #3 on: November 25, 2013, 12:06:37 PM »
The upright stock riding position can get tiring for long stretches at highway speeds where your torso is like a sail catching the wind. That's why a lot of members switch out to a euro or touring style bar, which are lower than stock. You don't get the extreme lean of clip ons or cafe bars, but you get a small forward lean that really helps at highway speed.
Offline Clasico
  • CB500 Four K1
« Reply #4 on: November 25, 2013, 12:47:21 PM »
Mine is an european market bike with lower bars than yours, still is a pretty upright position but i wouldn't change it for anything lower. It'll spoil the looks and the comfort in general.
BTW I'm trying to post some pics but can't do it!
Carpe Diem
Offline Bankerdanny
« Reply #5 on: November 25, 2013, 03:29:59 PM »
The pics need to be relatively small. I use a free program called IRFAN View to resize. 1200x800 seems to be a good compromise allowing for 3-4 pictures per post, but good resolution and detail.
« Reply #6 on: November 25, 2013, 03:35:37 PM »
yep, let her rev...5000 is just the beginning
Offline flatlander
« Reply #7 on: November 26, 2013, 04:38:20 AM »
i know what you mean. i have a 550f that has the same bars (if yours are stock). after getting used to it i find i can go 120/130kph for quite some time without problems. faster, and i need to go a bit lower to catch less wind.
i didn't get this bike for highways so won't mount a screen but if you will use it there for longer periods, it may be a good idea to get one.
as others have side, 5-6k revs is just where it starts. you can get it past 8k then shift at redline. of course, less is also fine for relaxed cruising but then you really need to shift down if you want to take off in a hurry.
compared to the 2-cylinders you're used to it's quite different. you need to pay more attention to engine speed and shift more depending on what you're after. but that's part of the fun!
to your other observations:
stiff clutch: not sure what you mean but it should go easy, although it comes on quite suddenly which may need getting used to.
notchy gears: they should also be really smooth so try after an oil change.
brakes: i've got a second disc (OEM) mounted on the front which is a real improvement.
the twisties... yes i think they were invented for this bike  ;)
Offline Airbusboy
  • Smooth as buttah.....
« Reply #8 on: November 26, 2013, 04:53:46 AM »
I recently restored a 74 CB550 that sat in a barn for 38 years. What a hoot this thing is to ride!  I also own an 83 CB1000C and believe it or not I find the 550 smoother and possibly even better handling!  Both bikes seem to be harder to shift if the oil level is even slightly over filled...I don't know/understand why but you might want to check that. Also the clutch pull is for sure harder on the 550 so it may be a normal trait. Get to know her and she will constantly put a smile on your face!
Offline Deltarider
« Reply #9 on: November 26, 2013, 05:15:14 AM »
The 500 Four was more or less the final blow to the British motorcycle industry and at BMW they said: that's it, we'll never be able to catch up, let's concentrate on other products than motorcycles (eventually they continued making them). At Benelli in Italy they could not think of anything else than making a copycat as the Chinese did later in the... 90s. Sometimes I believe it has something to do with the combination 500 and 4. I've owned two Peugeots 504, a model that was in production for over 37 years. Excellent cars to cross the Sahara desert, btw. We passed stretches at 90 km/h where even 4X4s had dug in.
The 500 clutch is not as easy as on modern motorcycles. Shifting should be like knife through the butter however. You may want to inspect the drivechain.
Both the 500 and the 550 have always been praised for offering a good riding position. With euro handlebars that is.
« Last Edit: November 26, 2013, 05:27:31 AM by Deltarider »
CB500K2-ED Excel black
Offline flatlander
« Reply #10 on: November 26, 2013, 05:34:51 AM »
hey delta, you're in amsterdam?
we're almost neighbours then, on an international scale at least ;)
Offline Chachi
« Reply #11 on: November 26, 2013, 06:02:39 AM »
How old is your clutch cable? A fresh Honda cable and adjustment may make the clutch seem smoother. Deliberate shifting may help smooth the gear experience out more as well. The 500s have some notorious shifting 'issues' compared to the 550s. I had a 500 for a couple of years and it was a lot of fun.
73 CB750 K3
72 CB500 K1 - Sold
75 MR50 Elsinore K1
Offline Deltarider
« Reply #12 on: November 26, 2013, 12:06:10 PM »
Yep, maybe I've seen yours parked in the Ferdinand Bolstraat.
« Reply #13 on: November 26, 2013, 12:30:38 PM »
+1.  You can try lubing the clutch cable but a new Honda cable is a good idea.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #14 on: November 26, 2013, 12:41:17 PM »
I put 400F bars on my 550F and find the riding position more wind resistant than the upright position on my 550K with OEM bars. Just make sure to zip your jacket up all the way before hitting the Autovia!
Speaking of which, the last time I was in Spain they had just finished Autovia A-7 along the Med. Nice stretch of pavement! Awesome views and pavement as smooth as a baby's butt! You probably won't be keeping up with the Audis, BMWs and Benz' but you can keep up with everyone else. I would love to ride that someday.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline flatlander
« Reply #15 on: November 27, 2013, 03:02:22 AM »
maybe... by some coincidence. i live in the east and may have stopped there picking up something?
the bike looks like this. i don't think there are many others of the type in town:
i've seen a nice 500k in the green colour scheme around. is that yours by any chance?
Offline Deltarider
« Reply #16 on: November 27, 2013, 04:23:28 AM »
Opposite a 'klerenzaak' or 'schoenenzaak' it was, close to the Albert Cuyp tramstop. Mine is black, Excel Black and has a parking spot in the garage.
« Last Edit: November 27, 2013, 04:31:39 AM by Deltarider »
Offline flatlander
« Reply #17 on: November 27, 2013, 05:30:44 AM »
i don't think it was me then. i don't live in that area and don't shop for kleren en schoenen - my riding clothes is all i need  ;)
wasn't yours that i saw. but it was in similarly good shape.
Offline Clasico
  • CB500 Four K1
« Reply #18 on: November 27, 2013, 05:52:25 AM »
Thanks gentlemen I'll take your various recomendations for easing up the clutch, lets see how it works.
Duanob, let me know whenever back in Spain. We could do some routes together around Madrid. There are some brilliant secondary roads round the mountains. It's like hundreds of Mullohands over here!
Carpe Diem
Offline Clasico
  • CB500 Four K1
« Reply #19 on: November 27, 2013, 06:05:02 AM »
Hi Deltarider, my bike has the same color and patten than yours. In fact she was imported some years ago from the Netherlands.
One thing that does not up in my case is the fact that the bike is a K1 and i've never seen that colour in this model, any ideas?
Carpe Diem
Offline flatlander
« Reply #20 on: November 27, 2013, 06:16:37 AM »
indeed, 500 k1 had different colours. some previous owner may simply have painted the tank and side covers, or replaced them with those from another bike?
Offline Clasico
  • CB500 Four K1
« Reply #21 on: November 27, 2013, 08:34:35 AM »
Then I guess they come from another bike cause both paint and lines are original and extremely well preserved thanks to a varnish coat. I just wondered if there was any last of the line K1s with that colour.
Carpe Diem
Offline Deltarider
« Reply #22 on: November 27, 2013, 10:56:28 AM »
One way to determine whether it's a European K2 is to check whether it has one central grease nipple underneath for the swing arm instead of two on either side.
To further identify consult the various Parts Lists @ Honda4fun.
http://www.honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb500
In 'CB500 prodotte fino al 1976' you'll find a separate Parts List for the 1976 500K2 [ED,F.G] which is a later model (3 years later) than the different K2 in the USA.
« Last Edit: November 27, 2013, 01:53:00 PM by Deltarider »
« Reply #23 on: November 27, 2013, 08:55:09 PM »
If you have the opportunity, try to replace the clutch lifter itself. They wear a "notch" in them on the 500, because it allows the rider to so easily change gears with a partial clutch pull when moving. Over time, this builds up a stiff stopping ridge in the screw, which causes trouble as time passes. If you find a new one, be sure to keep it greased: this will prevent the wear for a long time. Most people never greased it.  ;)
Offline scrichton
« Reply #24 on: November 28, 2013, 01:55:32 PM »
I'd probably summarise it as fun, but not fast.
If only I could find a modern cb400 engine to put into the frame... that would be funner! (yes I know it's not a word)
Also on revving to the redline, a lot of the test's I've read from the time of release say that the last 1000rpm before redline isn't actually that useable, it more noise and less go. Plus moving that down in your mind means no valve float and no headaches with things succumbing to stiction or friction too soon.
