Author Topic: K7 Float Question  (Read 754 times)
Offline AintNoEasyWay
K7 Float Question
« on: November 26, 2013, 07:53:47 AM »
Hi everyone, I'm on my last chore before putting my carbs back on my K7 -- adjusting carb floats. I started to adjust the tangs on each float and realized I wasn't haven't much luck getting them to change float height. I then looked at my floats and noticed that the floats on carbs 2 and 4 seem to hang much lower than those on 1 and 3, and it seems to more than just an issue of adjustment. But as a newbie, I want to be sure I'm right about this.
I've attached a photo below and hopefully you can see that two of the floats hang much lower. I checked the metal part of the float that comes in contact with the carb, and this metal piece seems like it's bent back further on the floats that hang lower.
These lower floats also appear to be marked 'n' whereas the floats the don't hang as low are marked 'k', like my old floats that I've replaced.
Hopefully this explanation makes sense. I just need to figure out if I've somehow been sent the wrong floats with two of my rebuild kits (everything else from the kit was correct). Thanks!
Re: K7 Float Question
« Reply #1 on: November 26, 2013, 09:17:29 AM »
Those look all the same.  Are they hanging up on a burr on the float pin?
To set them..just bend the tang (more forcefully) to get the top (flat part) of the floats to be in line with the top of the PILOT JET.
If you feel the floats are of different styles (buoyancy), and you want to continue to use them, you'll need to verify fuel height using the clear tube method...
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: November 26, 2013, 09:35:38 AM »
There is another "tang' to adjust float drop. They should be even, and there is a specification for 'float drop". Look at the float arm next to the OTHER POST, the post opposite of the ones pictured above. In the pictures above the pivot post that is shown is to the right of the picture. Look at the pivot post that would be to the left and you will see a tang on the float arm that comes to rest against the float pivot post that is used to adjust the float drop.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
« Reply #3 on: November 26, 2013, 09:53:00 AM »
Cool. Thanks for the replies. Yes, those other "tangs" are further back on the floats that have the letter "n" on them. I didn't know if it was possible to adjust this part of the metal and certainly didn't want to break it off.
Offline lucky
« Reply #4 on: November 26, 2013, 11:55:42 AM »
I have no idea what you are doing. The photos make no sense at all.
Just measure the float height with the carb upside down or laying on its side.
Use a ruler.
With the K7 and K8
The top of the float (when upside down ) should be level with the pilot jet.
K7 and K8 ONLY!. The float tang should be JUST touching.
You do not need to use any clear tube.
Just MEASURE like the book says.
The book says to measure BEFORE....BEFORE any clear tube method is used.
AND it is not even necessary to use that clear tube method.
« Last Edit: November 26, 2013, 12:03:30 PM by lucky »
« Reply #5 on: November 26, 2013, 12:00:48 PM »
sure they make sense, if you read the whole post.
he's not measuring float height, he's wondering why he's got different ball float sag  ::)
Offline lucky
« Reply #6 on: November 26, 2013, 01:34:12 PM »
look at the difference between photo #11 and photo#10
