Author Topic: 1972 CB750 Carb sync tool help  (Read 567 times)
Offline zekd
  • the "b" team
« on: November 26, 2013, 09:34:22 PM »
Hey guys,
I bought a carb sync tool from dcc. It came with the 4 brass pipes to hook up to the vacuum ports on the carbs. I don't understand how they're suppose to fit. is there a trick for this? Any help would be much appreciated.
Offline SOHC Digger
  • I'm not an
Re: 1972 CB750 Carb sync tool help
« Reply #1 on: November 26, 2013, 11:13:36 PM »
They should be threaded on the end.  The engine side of the carbs has a plug that you remove and insert the brass tubes and then connect to your gauges.
Offline HotCarl73
« Reply #2 on: November 27, 2013, 04:07:39 AM »
I recently did this and had some trouble fitting the brass tubes. A couple of them interfered with the choke linkage. I had to find a sweet spot for the choke lever while screwing the tubes in. Once they were in, the tubes were binding up the choke lever a little. I don't know if this is your problem.
1973 Honda CB750 Flake Sunrise Orange
1974 Honda CB750 Flake Sunrise Orange (In Pieces)
1995 Ural Tourist
2005 Honda 919
« Reply #3 on: November 27, 2013, 04:19:10 AM »
This could help.
Offline zekd
  • the "b" team
« Reply #4 on: November 27, 2013, 05:20:52 AM »
Just realized they sent me the wrong sizes... thats why they wont reach all the way in -_- thanks anyway guys!
