Author Topic: 750A Carb upgrade  (Read 2189 times)
Offline Fran Fitzpatrick
750A Carb upgrade
« on: November 28, 2013, 01:26:06 PM »
I've read with much interest the challenges other 750A owners have had with the unique carburetors installed on these bikes.  It seems that people that have install 750F carburetors on the 750A have been happy with the improved performance.  One of the reasons most have stated for the carburetor switch is the unavailability of the 750A manifolds.  My question is this, the 750A carburetors are a little smaller then the 750F carburetors.  What have other owners done in regards to adapting the larger 750F manifolds to the smaller cylinder head manifold intake?
Thanks for any reply's.
« Last Edit: December 11, 2013, 05:02:46 AM by kandrtech »
Offline raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: 750A Carb upgrade
« Reply #1 on: November 28, 2013, 01:41:26 PM »
The A head is identical to the 75, 76 F and 77, 78 K heads (same part number, too).
Only the carb-end of the "manifold" or "boots" are smaller.  The head-end is the same as the non-auto bikes.
« Last Edit: December 11, 2013, 05:02:55 AM by kandrtech »
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline shar001
« Reply #2 on: December 05, 2013, 12:26:31 PM »
So according to Kandrtech, can we swap the 750a head with 750k
Head, so it will fit the carb manifold. If its the case, it will be a great
Advantage and economical solution.   ;D
« Last Edit: December 11, 2013, 05:03:03 AM by kandrtech »
  • Moderator
« Reply #3 on: December 05, 2013, 02:14:47 PM »
??? Why swap the head?  They are the same already.
« Last Edit: December 11, 2013, 05:03:14 AM by kandrtech »
Offline shar001
« Reply #4 on: December 05, 2013, 07:32:30 PM »
oh! i got it now, head is the same but end of the carb manifold is smaller. sorry!! my bad
« Last Edit: December 11, 2013, 05:03:23 AM by kandrtech »
  • Moderator
« Reply #5 on: December 06, 2013, 05:22:39 AM »
Yep.  The A bikes have lower compression due to the pistons alone.
There's some "hidden" performance available in these motors . . . .  ;)
« Last Edit: December 10, 2013, 03:59:15 PM by kandrtech »
Offline jweeks
« Reply #6 on: December 10, 2013, 07:10:44 PM »
early K carbs, K intake manifolds, and a K (clutch) cam makes the automatics really wake up.;)
« Last Edit: December 11, 2013, 05:02:26 AM by kandrtech »
