Author Topic: F1 '76 cylinder head  (Read 1026 times)
Offline fr33man
« on: November 28, 2013, 04:31:06 PM »
Hey,
One of the bolts for the manifold is missing and I think I might jest try and find another cylinder head instead of trying to fix it with a helicoil or something..
I dont know much, and haven't found a head for a f model.. my question is, can I use from a k model as long as it's song?
Thanks in advance :)
Sendt fra min HTC One med Tapatalk
Offline mick7504
Re: F1 '76 cylinder head
« Reply #1 on: November 29, 2013, 01:05:05 AM »
Hey,
Just helicoil it mate if the threads fcuked.
That's easy enough to do.
If I was you
I'd be worried about me.
Offline fr33man
« Reply #2 on: November 29, 2013, 01:07:41 AM »
I know, but Its a Big hole.. previous owner drilled it up to approx 13 mm and put in a bolt with epoxy..
Offline mick7504
« Reply #3 on: November 29, 2013, 01:35:36 AM »
Well it is repairable if the head is good to go again.
You could either get the hole filled with weld and drill & retap the thread or machine up an insert with an external and internal thread and make a custom helicoil.
It all depends on if you want to let it know who the boss is.  ;D
But seriously mate, I wouldn't can it because of one buggered exhaust thread.
If I was you
Offline fr33man
« Reply #4 on: November 29, 2013, 02:21:49 AM »
Offline fr33man
« Reply #5 on: November 29, 2013, 02:21:58 AM »
Offline fr33man
« Reply #6 on: November 29, 2013, 02:24:37 AM »
True - it's not the biggest job to fix it but with lack of time and me wanting it back on the road again asap it could be an easy option to get a new one :)
Offline mick7504
« Reply #7 on: November 29, 2013, 02:31:14 AM »
That's fair enough mate.
You could repair it when time allows and either keep it for a spare or sell it to recover some of your outlay.
Good luck either way mate.  ;D
If I was you
Wobbly
« Reply #8 on: November 29, 2013, 02:49:17 AM »
Hey,
The one from the K7 is identical.
Offline bjbuchanan
« Reply #9 on: November 29, 2013, 09:57:16 PM »
Have you checked just how big the hole is? I had some big @ss holes drilled in my head only to find out that a regular old 12mm helicoil was find AFTER the "drill" and tap.
The drill for the 12mm IIRC is 21/64 although a common 5/16" works just fine with proper tapping technique. I bet you are right around there. Red loctite if the threads are so-so depth for the helicoil? The red loctite for the insert I mean.
Could also always pull it off and have a welder draw a bead for 20$. Gotta try to center the hole then tho
