Author Topic: SL350 or similar carb question  (Read 901 times)
Offline greenjeans
  • 1972 CB750K2
« on: December 03, 2013, 11:06:49 AM »
Picked up an SL350 the other day.   Certainly in nice shape, but it looks like PO did a bit of a resto on it some time ago.
Anyway, I'm rebuilding the carbs and noticed a couple of things.   Looks like there is 2 right side carbs - the air screws are on the same side as well
as the drain screws in the carbs.   no biggie there.
However,  each carb has a small nipple coming out of it with a hole  pointing downward.  On 750 carbs there are small tubes connecting the actual carb bodies.  Am I correct in assuming this doesn't need a tube/hose or anything ?   There doesn't seem to a hose to equalize the fuel/air in each carb body.
Re: SL350 or similar carb question
« Reply #1 on: December 03, 2013, 11:33:50 AM »
 Cv or screwtop type?
« Reply #2 on: December 03, 2013, 07:38:20 PM »
original cl350 carbs are cv type.  I have a few pair of these carbs and all have float bowl drain screws facing the same way(one facing out, one facing in).  Air screw should face to outside of the bike...iirc.  Watch out when replacing carb bodies, as there are at least three slightly distinct castings used over the years, but I think any of them could be made to work.
« Reply #3 on: December 03, 2013, 07:40:42 PM »
SL had cv the first year then switched to regular screwed tops.
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: December 03, 2013, 07:41:21 PM »
All normal. Post some photos-the SL was a very cool bike...Larry
« Reply #5 on: December 03, 2013, 08:04:39 PM »
oops...just realized the thread title distinctly says sl.  Where did I get cl from?
