Author Topic: Front end shimmy @ 40 MPH  (Read 1960 times)
benny365
« on: September 01, 2006, 07:30:22 PM »
My front end shimmys at 40 mph mainly when decelerating.  Possibly steering stem bearings or forks going bad?.
I replaced the tire, not that. (It needed it anyways)
What do you think?
73' 750
Offline Dave K
Re: Front end shimmy @ 40 MPH
« Reply #1 on: September 01, 2006, 08:53:59 PM »
My '73 K3 would do that also if the front tire was worn or the wrong tread pattern on the front tire was used. (my '81 Goldwing would also) I am sure you checked the usual other things like swingarm bushings, head bearings and wheel bearings also.Check your front fork fluid as well and make sure the front fork springs are sagged to much. This will change the front end geometry and decrease your rake and trail, possibly creating this condition. Unfortunately, this is not an uncommon happening with model. All it takes is one finger on the bars to prevent it also.
Offline Pinhead
  • 1979 CB652-ST
« Reply #2 on: September 01, 2006, 10:45:07 PM »
As mentioned, check (change) front fork oil. You may possibly need to change your rear shocks as well. My 650 does that slightly if I try to carry something heavy on the back (behind the back tire on the luggage rack). The extra ballast throws the gemotry of the bike off and causes the front-end to wobble.
« Last Edit: September 02, 2006, 07:55:55 AM by Pinhead »
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline DammitDan
  • Prodigal Son
  • It lives!
« Reply #3 on: September 01, 2006, 11:00:11 PM »
Check your spoke tension on the rear.  I had loose spokes that made it shake pretty badly, especially on decel.  Then I realized that I was constantly 2 seconds away from death and tightened them correctly  ;)
(then I got rid of spokes completely and went to mags!)
CB750K4
mikes
« Reply #4 on: September 02, 2006, 03:09:26 AM »
I believe all the 750s suffered from that problem. Try puting just one hand very lightly on the throttle at about 40mph and roll off quickly while leaving your left hand off the bars, it will shake a bit. Best remedy for that is a steering damper. They tend to stiffen up a loose condition with a mild fork angle on a heavy bike. When i raced on dirt tracks i would get a severe shimmy or wooble at high speed on a very light bike, espically on a mile dirt track, and the dampers helped a lot to correct that condition. We called it the shakes. If i complained about it, they would tell me to run it till it melts!
« Reply #5 on: September 02, 2006, 01:36:45 PM »
That can be a worn bearing, they call it a decell wobble. You said you changed tires. i had the same condition when I changed tires. i found the newer type tires have softer sidewalls so the recommended pressure was no long valid. I raised the pressures and it wne away. Try the easy way first is my motto.
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #6 on: September 02, 2006, 02:07:49 PM »
How bad is it - do you notice it with your hands on the bars or is this only noticed with hands off?
ALL bikes will do this to some extent at aprox 35 mph, it's caused by the trail. The road deflects the
steering and the trail straigtens it.
If you are feeling it with your hands still on the bars then you need to check the simple stuff first.
1) tyres and airpreasure.
2) wear and tear to bearings, start witht eh front wheel, steering head, rear wheel and swingarm pivot.
3) are the wheels running true, any rim/tyre damage etc
4)suspension, probably less likly as this will be evident at other times than just deceleration at 40.
In the UK anything over 40 years old only needs insurance and Fuel.
