Author Topic: Stuck Carbs  (Read 2357 times)
denone
Stuck Carbs
« on: May 20, 2005, 04:06:23 PM »
Hi, I have just picked up a set of carbs for my 74' CB550. Any ideas on how to get them freed up? The throttle slides and a couple of the floats appear really gummed up, not to mention the jets, I just can not get them out. Can I soak the whole set of carbs in carb cleaner, or will this destroy the 'O' rings etc? Any help would be appreciated, Thanks.
Offline oldbiker
  • I HATE RAIN
Re: Stuck Carbs
« Reply #1 on: May 21, 2005, 01:42:27 AM »
I cleaned a set of carbs using nail polish remover (Acetone, I think) and a kids paint brush. Worked for me.
Re: Stuck Carbs
« Reply #2 on: May 21, 2005, 02:19:14 AM »
Hmm...Do I have this right?  You want to save 30 year old, dried out, cracked, and hardened o rings?  What are you making?  Some kind of deteriorated art mobile?  Just joking.
Well, I suppose you could try soaking the whole bank in gasoline.  This may well dissolve the fuel deposits without attacking the o-rings.  Might take a few days of soaking, though.
I have gotten stuck carb slides free by squirting spray can carb cleaner on the slides only.  But, then I wasn't at all concerned about the o-rings.  And, I don't remember if they survived the procedure as I did overhaul them and replace all the non-metal pieces.
I'm pretty sure acetone will leech out any remaining plasticizers in the polymer components. (like the o-rings)  Perhaps if you work really quickly, though...
good luck,
Offline Einyodeler
  • Midnight bugs taste best!!!
Re: Stuck Carbs
« Reply #3 on: May 21, 2005, 03:37:29 AM »
Try Yamaha carb cleaner, it`s O-ring  friendly ;)
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
Zip
Re: Stuck Carbs
« Reply #4 on: May 22, 2005, 07:45:23 AM »
Yes, Yamaha Carb Cleaner is great stuff.  You could drop the whole thing into it and let it sit a coupke of days.  YCC comes in plastic bottles so it can't hurt plasic and rubber.
Zip
kansassteve
Re: Stuck Carbs
« Reply #5 on: May 22, 2005, 11:24:40 AM »
Where do you get Yamaha carb cleaner?
Offline dusterdude
Re: Stuck Carbs
« Reply #6 on: May 22, 2005, 12:32:55 PM »
probably a yamaha dealer
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Einyodeler
Re: Stuck Carbs
« Reply #7 on: May 22, 2005, 12:58:24 PM »
Go to your nearest Yamaha dealer and park right by the front door,run in and get the YCC and when you come back out and all the old timers are hanging around your bike tell them what model year it is and that Honda still supplies a lot of the parts for it to this day. ;) I get that all the time at gas stations or just stopped at a light and they`ll ask what year is that and I tell `em it`s a `72 and ride it over 100 miles roundtrip each day and most of them are just speechless.When is the last time you saw a `74 Yam,Suz or Kaw ridden daily? 8)
Offline dzachary99
  • There is always something to learn...
Re: Stuck Carbs
« Reply #8 on: May 23, 2005, 05:05:39 PM »
If all else fails, e-mail me I'll run them through a ultra sonic cleaner, It'll make run and LOOK like new.
misadie1@iwon.com
Doug
If my wife knew this web site existed, she'd freaken' go insane.
