Author Topic: Pd44a pumper  (Read 1787 times)
Offline Mafia
Pd44a pumper
« on: December 06, 2013, 06:05:28 PM »
Need info on these carbs in way of rebuild faq. Can't find much info, my slides are seized and only come loose after boiling water bath. Gotta pull the slides out and give them a good clean.just don't want to go in blind.ty
Of all the things I've lost, I miss my mind the most
Offline Bankerdanny
  • Endeavor to persevere
Re: Pd44a pumper
« Reply #1 on: December 07, 2013, 09:32:14 AM »
It's pretty straight forward.
Once the slides are out clean them and the bores GENTLY with 0000 steel wool and some carb cleaner or acetone. The goal is to remove any deposits without removing material from the slides or the bores. You can also use a green Scotch Brite pad. but again, don't scrub hard. Do not use sand paper of any type.
Offline Mafia
Re: Pd44a pumper
« Reply #2 on: December 07, 2013, 09:40:03 AM »
Don't know how to renove the slides. Once they are out cleaning them is no prob.ty for the info
Re: Pd44a pumper
« Reply #3 on: December 07, 2013, 10:48:33 AM »
Please revise your title as it is misleading. Theses are not 'pumper carbs'
These carbs have an accelerator pump, and not a diaphragm for each.
To remove the slides, you need to remove the carb top caps and then disassemble the linkage underneath to pull the slide out.
And get a clymer manual, download the shop manual from this site, and use the search function at the top of the page. All of these steps are outlined, typically with pictures...
Offline dusterdude
Re: Pd44a pumper
« Reply #4 on: December 07, 2013, 02:30:10 PM »
Flybox,you're pickin nits.if the rack has an accel plump and all four do pump gas,then they're pumpers
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Mafia
Re: Pd44a pumper
« Reply #5 on: December 07, 2013, 02:31:59 PM »
That's what I was thinking...
Offline dragracer
  • CB750F Dragbike
Re: Pd44a pumper
« Reply #6 on: December 08, 2013, 01:58:34 AM »
Agreed
Offline dusterdude
Re: Pd44a pumper
« Reply #7 on: December 08, 2013, 05:48:23 AM »
mark
1972 k1 750
1949 fl panhead
1998 cbr600 f3
Offline Mafia
Re: Pd44a pumper
« Reply #8 on: December 08, 2013, 06:55:51 AM »
Far as I can tell... there is no pd44a dissasembly in the downloadable manual
