Author Topic: 75 cb750f wheel on gl100 forks???  (Read 2237 times)
Offline fdbrat
« on: December 07, 2013, 10:42:24 AM »
Just like the tittle says. Can I use 75 cb750f wheel on the 77 gl1000 forks?
Will the twin rotors fit on the 750f's hub?
I know a hub swap is possible but I am running Lester mags.
The brakes are frozen on my 750, and I have a chance to grab a whole 77 gl1000 for cheap.
« Last Edit: December 07, 2013, 10:44:01 AM by fdbrat »
1975 CB750F
4-4, Dyna S and box
5 ohm coils / 5k ohm caps
In- .05 / Ex- .08
San Luis Obispo
Re: 75 cb750f wheel on gl100 forks???
« Reply #1 on: December 07, 2013, 12:17:45 PM »
Rotor sizes Are. Different
Offline fdbrat
« Reply #2 on: December 07, 2013, 12:53:56 PM »
So The wheel will fit. But the gl rotor won't button up to the 750 wheel?
Drill the rotor? Sigh...
I need breaks and figured if this all worked I'd get an upgrade too. Hmmm. I really dig my mags.
Other wise the hunt for stock brakes.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Xnavylfr
« Reply #3 on: December 07, 2013, 04:41:33 PM »
I also think the GL rotors are offset more than the CBs. The GL forks are about 2" wider. I think the GL and CB rotors were drilled the same to mount on the rim but different offset!
Xnavylfr(CHUCK)
Offline dusterdude
« Reply #4 on: December 07, 2013, 05:04:33 PM »
And you are correct
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline fdbrat
« Reply #5 on: December 07, 2013, 08:16:02 PM »
Would it bee to sketchy to add longer bolts and spacers on the rotor?
Bummer.
I mean... $100 for a complete GL1000 is a great deal.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Bankerdanny
  • Endeavor to persevere
« Reply #6 on: December 08, 2013, 11:57:02 AM »
I'm not sure why you would want to use the F wheel anyway. The '75 F would be a single front disk with a steel rim and the '77 GL1000 is a double disk aluminum wheel.  The 750F didn't get twin front disks until the switch to Comstar wheels in '77.
Offline Xnavylfr
« Reply #7 on: December 08, 2013, 04:24:14 PM »
I know the 75/76 GLs had aluminum D.I.D. rims.and can polish up very nice!! You could swap rims out so they both match!!
Xnavylfr(CHUCK)
Offline fdbrat
« Reply #8 on: December 08, 2013, 05:28:02 PM »
If I didn't have these Lester's I would use the GL rims. I like the low maintenance of these mags.
Basically I need to replace all the brakes. Complate fusion.  FUBAR.
I "Had" a chance to grab a complete GL.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Bankerdanny
« Reply #9 on: December 08, 2013, 06:13:29 PM »
Ah, that would make sense. You didn't mention the Lesters, which I believe support 2 disks, and if they don't Goldwing Lesters will.
Offline fdbrat
« Reply #10 on: December 08, 2013, 06:21:30 PM »
That's a great idea Danny. I hope the GL Lester's are the same style.
I keep my eye open for a front one. I suppose until then ill just go stock until I find the right buy.
Thanx fellas.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
« Reply #11 on: December 08, 2013, 06:24:23 PM »
I'm not sure about the '75-'76 f bike hubs, but I know early 750k(71-76) and gl1000 hubs are identical.  Just bolt the rotors, speedo drive and axle (and spacer/s?) from the gl on to your lester and it drops right into the gl1000 forks perfectly.  Not sure why someone has not pointed this out already.
Offline fdbrat
« Reply #12 on: December 08, 2013, 06:45:26 PM »
Ok cool. I did ask about a rotor spacer earlier. No response. Thanx sean. Man... I should of just grabbed the bike. Damn. Well. The hunt begins.
1975 CB750F
4-4, Dyna S and box
In- .05 / Ex- .08
San Luis Obispo
Offline Bankerdanny
« Reply #13 on: December 11, 2013, 12:21:27 PM »
Here you go, someone in the for sale thread selling GL1000 Lesters. Maybe he would trade the 750 Lester for the GL, although I think the CB version is worth more.
http://forums.sohc4.net/index.php?topic=132538.0
