Hi,
@Steve-o - I don't have the right wrench socket for the tricky #2 and #3 spark plugs, but so far I got 135psi off #1 and #4.
Stores are closed since so I'll have to cross my fingers and hope they are all roughly the same when I check it tomorrow.
@strynboen - Thanks again for your help, good sir.
I had #3 pod sitting crooked, there was a vacuum leak. I got it running but she struggle and appears to be running too rich, black smoke and bad throttle response (at least I hope that's what it is). #1 spark plug was a bit wet when I checked it, and #4 too.
http://vid1319.photobucket.com/albums/t673/Toustic/20140803_160648_zpsf741bb1b.mp4
Sorry, my stuff it always dark looking.
I should be receiving my carbtune an colortune early next week so I'll be able to tune it properly. For now I'll leave it be and take care of other little things.
I tried to see if this cheap a** rear set I found could work on the passenger peg holes for when I'll put the clip-on bars and aluminium seat.. It's not too bad actually
![](http://i1319.photobucket.com/albums/t673/Toustic/20140803_173649_zps75d729f5.jpg)
Also prepping the seat to make a fiberglass pan for the upholstery..
![](http://i1319.photobucket.com/albums/t673/Toustic/20140803_164039_zps3976cf4a.jpg)
Anyways, that's that for the weekend.
Cheers from Geneva's nasty weather,
Seb
