Author Topic: Largest rear tire for a CB350 Four  (Read 1208 times)
Offline hulsecc
« on: December 08, 2013, 06:47:52 PM »
I am looking to replace the tires on my cb350 four and I am looking at the avon tyres roadrider for a replacement.  What would be the largest rear tire that I could use for this bike?  I currently have 3.25-18 on front and 3.50-18 on rear.  I am also a little confused when I look at the new avon tire sizes.  Any information would be welcomed.  Thanks
CC
Re: Largest rear tire for a CB350 Four
« Reply #1 on: December 08, 2013, 07:28:32 PM »
I have Avons on my Z1 and love them.  The original tires on these bikes were measured in inches and most modern tires are measured in millimeters.
3.25" = 82.55 mm, so a 90/90-18 would be ideal....
 http://www.amazon.com/Avon-AM26-Roadrider-Front-Tire/dp/B000JMBKX0
3.5" = 88.9 mm, so a 100/90-18
http://www.amazon.com/Avon-Roadrider-AM26-Tire-Construction/dp/B000JMDO9S
Not a good idea to go wider, the tire wear will be abnormal and possibly cause bad handling.
Hope that helps
« Reply #2 on: December 08, 2013, 07:58:34 PM »
Hope that helps
+1.
These are the same sizes for my 350F. Run them at about 35 PSI front, 38 PSI rear if the bike is stock and you are about 150-170 lbs. Go to 40 PSI rear if she goes with you. ;)
Offline hulsecc
« Reply #3 on: December 08, 2013, 08:04:27 PM »
It's a Cafe build.  She will have to stay at home.  Since it is a cafe build, I like the look of the larger tire in back, but I don't want a bike that handles poorly.
CC
« Reply #4 on: December 08, 2013, 08:07:07 PM »
Even at the 100/90-18 size, I'd recommend adding air fork caps up front, and run 3-8 PSI pressure up there. This will do wonders for the entry into turns and the recovery from a deep one.
